Recommendations for a hefty power supply
MiXiN
Post by MiXiN » 16 Sep 2018, 23:42
I have a Manson EP-925 30A linear PSU here, however, there are numerous horror stories about these overvolting and blowing gear connected to it if stressed slightly.
I wouldn't trust it if drawing more than about 15 Amps, which brings me to the following question;
Can anybody please recommend a sturdy PSU capable of running a Zetagi B550? I think it draws around 25A.
There's a plethora of power supplies around, but there's very little around in terms of reviews.
My budget is around £150.
KlondikeMike
Call Sign: 9WR2000
Re: Recommendations for a hefty power supply
Post by KlondikeMike » 17 Sep 2018, 00:16
MiXiN wrote:
16 Sep 2018, 23:42
... Can anybody please recommend a sturdy PSU capable of running a Zetagi B550? I think it draws around 25A.
Build your own from surplus server power supplies. High current/quality, low price. Just need to put in a little effort.
https://www.rchelicopterfun.com/dps-600pb-build.html
9WR2000
Nitehawk
Post by Nitehawk » 17 Sep 2018, 04:20
I use a Mass 50 amp to run my kl 405, I did have the b550p and it ran them a treat, I also use a Ranger 2970n2 works well with radio as well, it is a switch mode type but suffer no interference from it, I hope this helps.
108EH002
Post by 108EH002 » 17 Sep 2018, 08:16
I use a 50 amp maas sps 50 psu running at 50%.
You can talk worldwide on CB = not 10 - 15 miles,
Freebanders know otherwise = test free.
27.555 Usb
Tim
Call Sign: 26AT239
Post by Tim » 17 Sep 2018, 08:32
You could use an ark welder, that would give you 180A output. ;)
Post by The Collector » 17 Sep 2018, 17:25
...only if there's a flood ;)
Transwarp
Call Sign: Viper
Post by Transwarp » 24 Sep 2018, 16:51
Tim wrote:
17 Sep 2018, 08:32
:lol: :lol: :lol:
"Did video really kill the radio star?"
kilimax
Post by kilimax » 24 Sep 2018, 17:29
I use a HP DPS-1200FB converted server supply. Easily provides 80A + at 13.5 volts (after modding)
There's a decent thread here on converted server power supplies.
They were available for buttons until the bit-coin mining brigade started using them. Still available but they fetch a bit more these days.
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
Tim
Call Sign: 26AT239
Post by Tim » 24 Sep 2018, 18:03
The Collector wrote:
17 Sep 2018, 17:25
And a flood there would be, of solder and components! ;)
wa10
Post by wa10 » 26 Sep 2018, 02:02
i built a supply to run a b550 about 30 years ago using a vintage arc welder transformer with some secondary windings removed to get about 17v,
it had single copper windings & plenty of iron in the core not multi tapped aluminium like they use nowadays,
of all the cb/ham supplies i have used, astron rs50 while far from perfect would be my choice,
they are crowbar protected & fairly stable under load, fit a soft start thermistor & you won't pop rectifier diodes or trip your house fuses at switch on, the other common cb/ham supplies are mostly unprotected ****,
sure you can get MUCH better quality heavier more expensive more load stable supplies but most of those don't like rf up em,
a b550 at full power pulls a lot more than 25a.
andrew013
Call Sign: 26AT013
Post by andrew013 » 28 Sep 2018, 08:55
i too use a 50 amp maas sps 50 psu and have had no issues i run a modded rm 500 on mine
