Power supply for a president Lincoln.
Pocketrocket2004
New User
New User
Post by Pocketrocket2004 » 25 Jul 2018, 16:55
Anyone recommend a power supply for a president lincoln mk1?
Ive heard that a 5 to7amp will be fine but im not sure.
Buick Mackane
Re: Power supply for a president Lincoln.
Post by Buick Mackane » 25 Jul 2018, 18:03
Pocketrocket2004 wrote:
25 Jul 2018, 16:55
If its running standard power (20 watts PEP SSB) Then it should draw around 7 amps, So i'd go for a 10 amp / 12 surge PSU, That way your not running it flat out,
Real men DX on 20m using dipoles made of cheap speaker wire ;)
cb4ever104
Post by cb4ever104 » 25 Jul 2018, 20:08
Hi .
Already mentioned a couple of weeks ago .
cb4ever104 wrote:
14 Jun 2018, 07:30
original45 wrote:
14 Jun 2018, 06:42
One I noted was the Lincoln mk1, I understand it should require a 10 amp fuse but actually has a 5amp fuse inline ?.
The manual says 4.5A , so I've no idea why you have a 10A there . A 5A seems fine .
Post by The Collector » 26 Jul 2018, 14:41
Always nice to have a bit extra as mentioned, plus you can always use the excess to power some 12v lights on say a Zetagi Transmatch meter etc, or even a small amplifier if you've got plenty of amps free.
original45
Call Sign: 45
Post by original45 » 27 Jul 2018, 10:45
Power supply.
I'm by far no radio expert but I have tried a couple power supplies recently. One simply impressed me.
I watch occasionally a YouTube guy,fredintheshed and a friend told me about this review to watch.
He did a video on a led power supply ,how stable and quiet it was.
So I purchased from the supplier he linked too for my Linc1.
I purchased the 33amp version. You need to add a power cord flex of which I added a quality iron flex .
I then run the supply and by adjusting a vr set voltage to 13,8v which has stayed bang on.
I will add a digital voltage display to front in time but have one sitting on top monitoring why used.
Added rubber feet bellow to lift it off deck to aid cool air flow.
Fan is pretty quiet too and effective.
Been using it often with no complaints.
If I'm honest I much prefer a 12v battery, 120amp leisure battery .I have two pluss car batteries .
Hardly ever needs charging and has 0 noise.no need for fans ,no noise and will not become faulty with use for Yeats maybe a decade or longer if cared for.
Can be placed in a battery box for correct safe storage.
For me a battery ,especially if using a amp too.
Post by The Collector » 27 Jul 2018, 13:37
I sold an old Sony Playstation transformer at a car boot sale last weekend. I know of people that have adapted those for use with radios. I believe you can get about 15-18amps use from them and they can be picked up for a couple of quid or you may have one in you loft you can mess with if reasonably competant with electrics (don't go blaming me if you zap yourself though ;) ) lol.
