hy~gain clr2
26TM5890
Re: hy~gain clr2
Post by 26TM5890 » 16 Jun 2018, 22:59
best to spray it with; http://www.acf-50.co.uk
Ur5by9
Re: hy~gain clr2
Post by Ur5by9 » 17 Jun 2018, 09:33
The Collector wrote:
16 Jun 2018, 22:31
It'll look awesome, although it's one big bugger. Diameter of the legs is about 15ft :)
Kin Ell -
Right away outside and fly it up I need to see this.
superstar
Re: hy~gain clr2
Post by superstar » 17 Jun 2018, 13:00
:) right lads its up, just got coax and check swr and adjust if necessary :)
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
superstar
Re: hy~gain clr2
Post by superstar » 17 Jun 2018, 13:13
here’s a better pic, coax on, swr bang on, working superb
over the moon with it, there’s not many chimneys with one of these on :D
Cb handle
kilimax
Call Sign: GM0BRJ
Re: hy~gain clr2
Post by kilimax » 17 Jun 2018, 16:05
Looks excellent. Radials are almost as long as the radiator! :lol:
I see you have used two of the double U clamps. That's how I mount my verticals. Good job :thumbup:
What's the useable bandwidth?
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
superstar
Re: hy~gain clr2
Post by superstar » 17 Jun 2018, 16:24
kilimax wrote:
17 Jun 2018, 16:05
thanks for comments, it says on the instructions 2mhz,
the swr is good on lo/mid/hi bands and creeps up to about 1.8 nearer ch40 cb27/81 band so ideal really
here’s a better pic of the pole joint area
it was hard work lugging that up there on me own and the wind had started to get up a bit, glad i done it though :thumbup:
Cb handle
prettypolly
Call Sign: 26FB185
Re: hy~gain clr2
Post by prettypolly » 17 Jun 2018, 20:12
Proper job well done
Ur5by9
Re: hy~gain clr2
Post by Ur5by9 » 17 Jun 2018, 20:35
Well done, that is some antenna in the air. Those radials are long for sure.
Be interested to see how this performs against your predator antenna, as I am thinking about changing my 827 to the predator .
Now have a beer and enjoy your hard work.
The Collector
Re: hy~gain clr2
Post by The Collector » 18 Jun 2018, 15:34
Literally sex-on-a-stick :)
andymuza
Re: hy~gain clr2
Post by andymuza » 19 Jun 2018, 21:26
I had a CLR-2 up at my mams for about 20 years. When I moved out I intended taking it down but never did. It never failed me once in the 10 years I used it. It was one hell of an antenna and the best vertical I have ever owned.
Unfortunately some builders took it down and wrecked it. I was devastated.
