hy~gain clr2
- Call Sign: 26TM5890
Re: hy~gain clr2
best to spray it with; http://www.acf-50.co.uk
Elecraft K2
President Grant II Premium
- Ur5by9
Re: hy~gain clr2
Kin Ell -The Collector wrote: ↑16 Jun 2018, 22:31 It'll look awesome, although it's one big bugger. Diameter of the legs is about 15ft
Right away outside and fly it up I need to see this.
- superstar
Re: hy~gain clr2
right lads its up, just got coax and check swr and adjust if necessary
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- superstar
Re: hy~gain clr2
here’s a better pic, coax on, swr bang on, working superb
over the moon with it, there’s not many chimneys with one of these on
Cb handle
Cb handle
- Auldgeek
- Call Sign: GM0BRJ
Re: hy~gain clr2
Looks excellent. Radials are almost as long as the radiator!
I see you have used two of the double U clamps. That's how I mount my verticals. Good job
What's the useable bandwidth?
Auldgeek - Drew
- superstar
Re: hy~gain clr2
thanks for comments, it says on the instructions 2mhz,
the swr is good on lo/mid/hi bands and creeps up to about 1.8 nearer ch40 cb27/81 band so ideal really
here’s a better pic of the pole joint area
it was hard work lugging that up there on me own and the wind had started to get up a bit, glad i done it though
Cb handle
Cb handle
- prettypolly
- Call Sign: 26FB185
Re: hy~gain clr2
Proper job well done
- Ur5by9
Re: hy~gain clr2
Well done, that is some antenna in the air. Those radials are long for sure.
Be interested to see how this performs against your predator antenna, as I am thinking about changing my 827 to the predator .
Now have a beer and enjoy your hard work.
Re: hy~gain clr2
Literally sex-on-a-stick
- andymuza
Re: hy~gain clr2
I had a CLR-2 up at my mams for about 20 years. When I moved out I intended taking it down but never did. It never failed me once in the 10 years I used it. It was one hell of an antenna and the best vertical I have ever owned.
Unfortunately some builders took it down and wrecked it. I was devastated.
