hy~gain clr2
superstar
hy~gain clr2
Post by superstar » 14 Jun 2018, 07:43
after 3 years up on the stack the new old stock clr2’s swr went into the red, went up yesterday evening to have a look and part of it has broken at the base, looks as though it’s been eaten away by corrosive smoke from the fires we have in winter, the same thing happened to the starduster i had up, but i just put it down to salt air living close to the sea, ill put some pics up of the damage when i get it down, ive got some other stuff to put up though, hygain penetrator 500, avanti astroplane, shakespeare big stick, vector 4000, so off air temporarily :(
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
prettypolly
Call Sign: 26FB185
Re: hy~gain clr2
Post by prettypolly » 14 Jun 2018, 12:10
I sold mine within a week gaining a handsome profit
Auldgeek
Re: hy~gain clr2
Post by Auldgeek » 14 Jun 2018, 16:00
prettypolly wrote:
14 Jun 2018, 12:10
So you will have made "Hy-Gain" then? :D
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
superstar
Re: hy~gain clr2
Post by superstar » 14 Jun 2018, 18:28
here’s what’s happened
Cb handle
The Collector
Re: hy~gain clr2
Post by The Collector » 14 Jun 2018, 18:39
Maybe metal fatigue helped that along? Too-ing and fro-ing in the wind over a couple of years may have been enough to weaken it and corrosion compounded it.
Whack up the Ham Int. Hy-Power I sold you! That will be a sight :)
superstar
Re: hy~gain clr2
Post by superstar » 14 Jun 2018, 18:42
oh yeah i forgot about that one, its under the bed :)
Cb handle
superstar
Re: hy~gain clr2
Post by superstar » 14 Jun 2018, 18:43
clr2 spares or repairs anyone?
Cb handle
superstar
Re: hy~gain clr2
Post by superstar » 15 Jun 2018, 07:22
i filmed the taking down in time lapse, check it out
https://youtu.be/vsKALudZLF8
Cb handle
Ur5by9
Re: hy~gain clr2
Post by Ur5by9 » 15 Jun 2018, 12:17
How do you rate this antenna ?
I have a Sirio 827 and looking for something different.
Super penetrator 500 also on the short list
superstar
Re: hy~gain clr2
Post by superstar » 15 Jun 2018, 13:16
works ace, but obviously there’s a weak point,
Cb handle
superstar
Re: hy~gain clr2
Post by superstar » 16 Jun 2018, 16:22
The Collector wrote:
14 Jun 2018, 18:39
i’ll see if i can bung it up, should look pretty impressive up on the stack :D
Cb handle
Ur5by9
Re: hy~gain clr2
Post by Ur5by9 » 16 Jun 2018, 19:46
Look forward to seeing fly high - don't forget pics
superstar
Re: hy~gain clr2
Post by superstar » 16 Jun 2018, 19:52
Ur5by9 wrote:
16 Jun 2018, 19:46
there’ll be pics, just gotta check all nuts n bolts are there
i’ll try and get it up within the next few days
Cb handle
The Collector
Re: hy~gain clr2
Post by The Collector » 16 Jun 2018, 22:31
It'll look awesome, although it's one big bugger. Diameter of the legs is about 15ft :)
Buick Mackane
Re: hy~gain clr2
Post by Buick Mackane » 16 Jun 2018, 22:35
If you don't report back within a few days with photos we'll just presume you've done a rod hull :lol:
5/9 QSB Via The bureau :yawn:
