K40 antenna any good
prettypolly
Call Sign: 26FB185
Re: K40 antenna any good
Post by prettypolly » 12 Jun 2018, 20:29
It could make a 1/4 wave ant with a modification
wa10
Post by wa10 » 12 Jun 2018, 21:56
The Collector,
my t40 was on a magmount, i can't remember what the mag looked like, seem to remember a rounded groove that the bearings clamp into & a chrome dome, but that's all.
cb4ever104
Post by cb4ever104 » 13 Jun 2018, 07:11
For me the K40 is the Cobra 148 GTL-DX of the antenna world . Sure , it isn't the best CB antenna out there , and they're easy targets to punch holes in . But for me it's a piece of iconic CB equipment that's got classic written all over it . Well actually it's got K40 written all over it :) . Every time I twist that little coil onto it's base I get thrown back to the late 70s when it all began . And for me that's what it's still all about . Nostalgia ! :)
canuck777
Call Sign: 2e1mha
Post by canuck777 » 13 Jun 2018, 12:43
prettypolly wrote:
09 Jun 2018, 19:17
Hi i want to ask is the k40 antenna any good or is there better ones out there ..
Hi, for what they are - A based loaded shortened whip, they work very well. i'll give you an example. years ago, a blind cb and ham friend of mine had a converted uk 27/81 rig on the fm portion of the 10 meter band, 4 watts out into mobile K40 literally on a bisquit tin lid :clap: with no ground plane wires, on the carpet on his living room floor. he put out a call and a mid west USA station came back 5+9 and gave him a 5+9. solid copy for 15 minutes like he was down the road. with such a very poor ground plane indoors ground floor as well, it proved the K40 can deliver. ok there was good skip conditions but even so ...
The Collector
Post by The Collector » 14 Jun 2018, 18:50
wa10 wrote:
12 Jun 2018, 21:56
The Collector,
Ok cheers for the info. I'll keep looking on ebay.
My Espace's hatch edge is fibreglass so I was obviously unable to fit the hatch mount to it. If I could make a t40 to SO adapter base it'd be my weapon of choice for mobile use but it'd be almost impossible for me.
I ended up drilling through the steel roof and putting an SO mount on there. There are fibreglass, steel, aluminium and plastic panels on the bloody thing to save weight!
One day, I'll get myself a Sirio 4000/5000 turbo, but for now a 49p Mil145 thing will suffice.
The Collector
Post by The Collector » 14 Jun 2018, 19:04
One thing to mention when buying a well-used K40 is thst the mount can become a bit slack and not as tight as when new. If vibrated, especially with the UK's potholed roads, there is a very slight risk of it coming loose and falling off. You can use a thin ring of rubber on the mount to help make the fitting a bit more snug and tight.
This is the reason I preferred the t40 back in the day with it's better (and lockable with a little security key to stop it getting swiped as easily) twist-ring mounting system as well as its tapered whip that didn't sway about half as much.
The performance was exactly the same as the K40 though which won't be a surprise to anyone.
