Superstar 2400
Posted: 03 Jun 2018, 09:40
Hi All.
I've an issue with my SS2400 . Basically it doesn't switch to give the full VCC to the driver and final when on SSB . It gives the same AM/FM 5-6V regardless of the mode . Now if it was the typical 010/EPT3600 clone board , then I'd know where to go to sort this out . But it doesn't . It uses the wonderful EPT240010Z board (thanks Ranger !) , and the pcb layout is completely different . I've emailed Ranger and they have no information on this pcb . Just wondering if anyone on here had anything technical on it . If not then I'll just need to try and go through it visually bit by bit starting from the mode switch .
Sammy
Sammy
