President Lincoln mk1 filtering upgrade ?
108EH002
Post by 108EH002 » 27 May 2018, 20:20
Have got a chipswitch Lincoln mk1,but at the house I get S9 of white noise on the radio while in rx ( 2 unmodded Lincolns were the same so not the chipswitch ),can the filter inside be upgraded/and get the noise blanker to actually work unlike at present,with better available components in 2018 ?,Thanks in advance.
Many freebanders know otherwise = test free.
27.555 Usb
Call Sign: n0call
Re: President Lincoln mk1 filtering upgrade ?
Post by ch25 » 27 May 2018, 21:50
There are 2 possibilities:
1. Move to quiet neighbourhood.
2. Find noise source and get rid of it.
No radio mod gonna help you.
I would start with house you live in. Cut the power, check on battery if noise disappears or not.
108EH002
Post by 108EH002 » 27 May 2018, 23:10
Noise source is close to house,drive a few hundred ft and it will disappear,have tried battery/isolated from own main supply,leaving it off a few hours to allow any capacitors in house to dissipate aswell Chris.Some radios not as bad as other's,radios with lcd displays like Lincoln + Ranger 2950 etc seem worse than analougue needle on meter,maybe just too sensitive for modern psu's that surround us.
Very annoying when you pick up unusually high interference wise/bloody chip pan,but whats the point when they are firing microvawe signals/PLT etc,still take the same tax/vat on new radio purchases,even with no guarantee you can actually hear anything,even when it is set up right {bnghd} rant over.
27.555 Usb
