Help identifying these antennas
NightProwler
Call Sign: 163TM186
Re: Help identifying these antennas
Post by NightProwler » 27 Mar 2018, 14:40
Thank you Andrew. Looks like this Tornado is going to go up soon then :D
andrew013
Call Sign: 26AT013
Post by andrew013 » 27 Mar 2018, 15:38
NightProwler wrote:
27 Mar 2018, 14:40
dont forget to put coil back in it proper place over the antenna tho lol
NightProwler
Call Sign: 163TM186
Post by NightProwler » 27 Mar 2018, 16:09
I just did :D
prettypolly
Call Sign: 26FB185
Post by prettypolly » 27 Mar 2018, 18:28
andrew013 wrote:
27 Mar 2018, 14:34
bottom one defo a tornado radilals should be approx 2000mm or 6ft 7 inch long
Your are correct sir.
cubwolf
Call Sign: M3CBY
Post by cubwolf » 27 Mar 2018, 19:28
The Tornado is a copy of the Comtell also known as the electronica special.
I had one a week in the 80s as it used to break on that plastic insulator
andrew013
Call Sign: 26AT013
Post by andrew013 » 27 Mar 2018, 23:01
cubwolf wrote:
27 Mar 2018, 19:28
it is indeed a copy of the electronica special it worked very well , i changed mine many many moons ago as we had a full on gale and i watched the tip bend to below its base , talk about fishing for whales , next day i put an original A99 up , gave tornado to my mate who promptley said it was the best ariel he ever had and i worked brasil on the a99 very next day , a new dxcc for me so i was happy too
prettypolly
Call Sign: 26FB185
Post by prettypolly » 28 Mar 2018, 21:55
Old topic and my old antenna years ago
grafter
Post by grafter » 29 Mar 2018, 13:50
That's the version I had PP, by the time I finally took it down the fibreglass section was peppered with holes as I moved fixings around, they had a habit of opening up due to the bolts rubbing where they went through the tube. ISTR it had a strange arrangement at the base with the SO239 fixed into a short ali tube that was wired to a puck that sat inside the fibreglass tube.
For its faults it performed very well and looked the part on top of 30ft of scaffolding, in fact I only replaced it after acquiring a Sigma IV.
