Dynamike
- Call Sign: BPO6O
Dynamike
Got a Dynamike tx ok fm ssb looks like its not doing anything any one have the wiring code for it looked at one it says blue and black to gether that's rx one is screen 3 is tx 2 is audio that's how I wired it battery good but not working right any thoughts thanks'
- prettypolly
- Call Sign: 26FB185
Re: Dynamike
Sorry your post doesn't make any sense at all
- ROTEL240
Re: Dynamike
What radio is it wired for, is the mic gain up full on the radio.
- Call Sign: BPO6O
Re: Dynamike
The mic is wired for the super star mic gain full up but when talk on ssb the meter needle only moves if I talk right up to the mic head when I switch to fm needle moves as should like I said plug is wired 1-and 3 tx 4 it says black and blue wires on pin 4 2 is white on 2 pin not got pa to try and not had any one come back when I call
- Call Sign: 108TM127
Re: Dynamike
Is the audio loud on FM and does the radio work ok with a normal mic ? .
- Bigdave
Re: Dynamike
That's how ssb works on voice peaks,unlike am/fm.....................
26 TM 1248
WINNER of INB4TL, the big battle edition 16/07/23
OFTEN IMITATED,BUT NEVER INTIMIDATED.
WINNER of INB4TL,the no interest edition 18/03/24
Re: Dynamike
Just a thought but is the battery good ? if there is a battery in it .
- astradyne
Re: Dynamike
Get a radio report on FM. If your TX audio report is quiet try a new battery.
If the mic is making the radio TX and you have audio (which you appear to have if the needle is moving on SSB TX) then the mic looks to be wired correctly.
Re: Dynamike
we do not use FM here in the USA. but from what I remember about FM it does not swing the needle on TX talking. it just shows a dead key and stays in that one basic location as you talk. SSB when you key up the needle should be at the zero location and swing up as you are talking. hard to understand just what is being said here but looks like the mic may not be working properly. you never did answer as to if you have tried another mic to see if the radio is working properly.
- Call Sign: BPO6O
Re: Dynamike
just found out that the blue wire should be connected to screen will try that see what happens let you all no tomorrow thanks for all the replies
- Call Sign: BPO6O
Re: Dynamike
got it working but low modulation when I turn to max nothing alters stuck again is it a bin job it looks brand new got it in a deal
- NightProwler
- Call Sign: 163TM186
- Call Sign: BPO6O
Re: Dynamike
Its the dynamike plus CA--72
- Call Sign: BPO6O
Re: Dynamike
Working 100./. now got the wiring right the white should be with the screen .thanks to all for reply's
