super star 360
Tom
Call Sign: BPO6O
super star 360
Post by Tom »
I have a super star 360 that has had 6 band switch put on and had some sort of Eprom for uk 40 which is not on frequency .so I would like it put back to low--mid--hi 3 band and e prom sorted is it a big job :?
cb4ever104
Re: super star 360
Post by cb4ever104 »
I presume you mean a 360FM , and not a 360 ? They're different radios .
Putting it back to standard can be a time consuming job . If the band switch has been done as well then the front of the radio radio will need stripped . Saying that , I usually do that anyway to give the switches a clean at the same time . The mod will need removed . The band switch will need to be opened and moved back to a 3 pos (or replaced) . Then it'll need rewired , and maybe some tracks resoldered . Once complete it'll need a complete retune . I don't know if I'd describe it as a "hard" job , but you need to be competant and know what you're doing .
Tom
Call Sign: BPO6O
Re: super star 360
Post by Tom »
Thanks might just have the Eprom sorted then uk 40 the last two numbers are wrong should be 1--2 but its 2not showing the one
astradyne
Moderator
Moderator
Re: super star 360
Post by astradyne »
A few Hz won't really make a noticeable difference on FM mode. If people can hear you clearly and you can hear them it shouldn't be a worry. Also you could just the course tune to bring it on frequency.
If you do need a 3 band switch I have one here from a 360FM I've been breaking for parts.
Tom
Call Sign: BPO6O
Re: super star 360
Post by Tom »
Thanks will remember that just looking at the pc board just like a mark 2 cobra
cb4ever104
Re: super star 360
Tom wrote: 01 Mar 2018, 13:01 just like a mark 2 cobra
It'll be exactly like a mkII Cobra . They both used the same pcb .
timbob58
Call Sign: 26tm957
Re: super star 360
Post by timbob58 »
i've just been playing with one .360fm had a six band swich in there
pain in the arse doing the track's on the board.. just need a little ailment now.
this lot came out :?
Mudslinger
Re: super star 360
Post by Mudslinger »
That looks like an original stealth eprom.
timbob58
Call Sign: 26tm957
Re: super star 360
Post by timbob58 »
Mudslinger wrote: 02 Mar 2018, 09:53 That looks like an original stealth eprom.
that ic was soldered to the vco rf shield.
that's the second one i've taken out now
just wanted the radio's standard
Mudslinger
Re: super star 360
Pretty sure that was how they were done by the importer in the isle of man. Not the best of jobs...
Otter
Call Sign: 26TM439
Re: super star 360
Post by Otter »
It was. That was original as supplied; the chip on top of the VCO cover will be marked TBP28L22N. The Hi/Lo switch would switch between UK and multimode.
astradyne
Moderator
Moderator
Re: super star 360
Post by astradyne »
Mudslinger wrote: 02 Mar 2018, 11:18 Pretty sure that was how they were done by the importer in the isle of man. Not the best of jobs...
Some had the TBP28L22N mounted on the back of the mic socket. Still not ideal, but looked tidier.
Otter
Call Sign: 26TM439
Re: super star 360
Post by Otter »
astradyne wrote: 03 Mar 2018, 00:35
Yes, later on the radios had to be imported without the code on the chip to do the naughty channels. From memory, the radios were supplied with a replacement chip in a bag, and instructions on what to do to open up the radio. These had the chip in a socket on a piece of stripboard screwed to the mike socket.
I would like one of these with the chip on a socket if anyone has one for sale, but it MUST have the original stealth front.
