super star 360
- Call Sign: BPO6O
super star 360
I have a super star 360 that has had 6 band switch put on and had some sort of Eprom for uk 40 which is not on frequency .so I would like it put back to low--mid--hi 3 band and e prom sorted is it a big job
- cb4ever104
Re: super star 360
I presume you mean a 360FM , and not a 360 ? They're different radios .
Putting it back to standard can be a time consuming job . If the band switch has been done as well then the front of the radio radio will need stripped . Saying that , I usually do that anyway to give the switches a clean at the same time . The mod will need removed . The band switch will need to be opened and moved back to a 3 pos (or replaced) . Then it'll need rewired , and maybe some tracks resoldered . Once complete it'll need a complete retune . I don't know if I'd describe it as a "hard" job , but you need to be competant and know what you're doing .
Sammy
Sammy
- Call Sign: BPO6O
Re: super star 360
Thanks might just have the Eprom sorted then uk 40 the last two numbers are wrong should be 1--2 but its 2not showing the one
- astradyne
Re: super star 360
A few Hz won't really make a noticeable difference on FM mode. If people can hear you clearly and you can hear them it shouldn't be a worry. Also you could just the course tune to bring it on frequency.
If you do need a 3 band switch I have one here from a 360FM I've been breaking for parts.
- Call Sign: BPO6O
Re: super star 360
Thanks will remember that just looking at the pc board just like a mark 2 cobra
- cb4ever104
Re: super star 360
It'll be exactly like a mkII Cobra . They both used the same pcb .
- timbob58
- Call Sign: 26tm957
Re: super star 360
i've just been playing with one .360fm had a six band swich in there
pain in the arse doing the track's on the board.. just need a little ailment now.
this lot came out
this lot came out
"The difference between genius and stupidity is that genius has its limits"
- Mudslinger
Re: super star 360
That looks like an original stealth eprom.
- timbob58
Re: super star 360
that ic was soldered to the vco rf shield.
that's the second one i've taken out now
just wanted the radio's standard
- Mudslinger
Re: super star 360
Pretty sure that was how they were done by the importer in the isle of man. Not the best of jobs...
- Otter
- Call Sign: 26TM439
Re: super star 360
It was. That was original as supplied; the chip on top of the VCO cover will be marked TBP28L22N. The Hi/Lo switch would switch between UK and multimode.
- astradyne
Re: super star 360
Some had the TBP28L22N mounted on the back of the mic socket. Still not ideal, but looked tidier.Mudslinger wrote: ↑02 Mar 2018, 11:18 Pretty sure that was how they were done by the importer in the isle of man. Not the best of jobs...
- Otter
Re: super star 360
Yes, later on the radios had to be imported without the code on the chip to do the naughty channels. From memory, the radios were supplied with a replacement chip in a bag, and instructions on what to do to open up the radio. These had the chip in a socket on a piece of stripboard screwed to the mike socket.astradyne wrote: ↑03 Mar 2018, 00:35Some had the TBP28L22N mounted on the back of the mic socket. Still not ideal, but looked tidier.Mudslinger wrote: ↑02 Mar 2018, 11:18 Pretty sure that was how they were done by the importer in the isle of man. Not the best of jobs...
I would like one of these with the chip on a socket if anyone has one for sale, but it MUST have the original stealth front.
