Afternoon all.
I have just been digging in an old junk box & found a Altai DMC510 power mic.
It looks if it takes a AA battery.
It's a bit on the grubby side but I think it will clean up nicely.
It's worth the effort to clean & put a battery in.
What are they like audio wise.
Any experience you have of these mics would be appreciated.
Andy 630
Altai DMC510
- dt630
- Call Sign: 26dt630
Altai DMC510
Midget
“Light travels faster than sound. This is why some people appear bright until you hear them speak.”
WWG1WGA
WWG1WGA
- astradyne
Re: Altai DMC510
These old Altai DMC510's aren't half bad. A tried and tested old school power mic that's served many people well over the last three decades.
Definitely worth a clean up and a new battery!
- Mudslinger
Re: Altai DMC510
I have a couple here. I don't rate them to be honest and the elements usually get removed to fix up other non running mics.
Or they go with radios being sold.
Re: Altai DMC510
My first power mic in the 70's, they came with different style grills & brand names over the years 1.5v & 9v versions but all more or less the same inside,
sound nasally/restricted bandwidth in stock form, i used to mod them in the 70's & early 80's, changed a few capacitors to give more bass & trebble,
also used the small amplifier boards found in these mics in several homebrew base mics with good results.
W8JI
- dt630
Re: Altai DMC510
Thanks guys.
I'll get out the tooth brush & splash out on a new battery &
put on my old Harrier CBX & see if I can find anyone to talk to.
Andy 630
Andy 630
Midget
WWG1WGA
WWG1WGA
Re: Altai DMC510
As wa10 said, they always sounded a bit bassy and muffled. I always took the paper/material cover off the front of the mic' element which cleared it up a tad
They used to cost a tenner for good reason.
- Mudslinger
Re: Altai DMC510
They sound just like a cheap replacement mic, only a bit louder.
