signal 1001
Tom
Call Sign: BPO6O
signal 1001
Post by Tom » 25 Sep 2017, 16:27
Echo master plus humming noise its the one that runs off the power pack put ferrite rings on power lead still humming when I key up did try another power pack still doing it any help thanks
speeddemon
Re: signal 1001
Post by speeddemon » 25 Sep 2017, 20:42
Hi tom id would Check the power/filter caps in radio and power mic ..one or two caps maybe on way out ..and check the mic wiring If the gnd isn't touching audio wire n mic is wired correctly gd luck n pce n 73's
