27.560 muppets
NightProwler
Call Sign: 163TM186
27.560 muppets
Post by NightProwler » 02 Sep 2017, 19:52
I have noticed recently a lot of stations calling CQ on 555 then QSY'ing to 560. This winds me up as they splatter onto 555 if they are strong enough to me. Why the hell dont they move a bit further away? {bnghd}
Rant over :D
andymuza
Re: 27.560 muppets
Post by andymuza » 02 Sep 2017, 20:06
It makes no sense but muppets do stupid things.
Chances are if they cause splatter to you on 555, you will cause splatter to them on 560 so just keep calling.
NightProwler
Call Sign: 163TM186
Re: 27.560 muppets
Post by NightProwler » 02 Sep 2017, 21:14
Thats what I cant understand because I hear a few Italian stations doing it when 11M is really active as it has been recently, So they must be getting it from the other stations calling on 555. Odd.
wa10
Re: 27.560 muppets
Post by wa10 » 02 Sep 2017, 22:44
Traditionally the Italians were well known for overdriving amplifiers creating IMD that causes issues to near by frequencies, they often used class C amps on ssb too.
Its not all their fault nor are they alone in thinking pumping 20w ssb into cb amps is ok because it says so in the user manual,
the manufacturers also put ssb switches on class C amps which is almost as stupid as claiming up to 4x what the amplifiers will output with reasonable IMD levels,
there are no specs to meet for cb amps so they can claim anything to lubricate your wallet.
108xx002
Call Sign: 108TM002
Re: 27.560 muppets
Post by 108xx002 » 03 Sep 2017, 07:05
It's always the same stations...1LR001 for one. Being the group president he should know better, but alas he is a bad teacher and a fud TBH. I have told him many times to QSY but he does not give a flying f...monkey about it :/ CB has a bad name anyway without the need for DQRM.
The end is nigh...for 11m anyway as all that will be left on the band will be QRM'ers QRM'ing other QRM'ers :/
Being a ham has benefits...certain religions stay away from me.
Day in and day out swl to same QRM from the same ops but on a different date.
If at first you do not succeed...it's because you never tried hard enough...
Call Sign: n0call
Re: 27.560 muppets
Post by ch25 » 03 Sep 2017, 12:13
NightProwler wrote:I have noticed recently a lot of stations calling CQ on 555 then QSY'ing to 560. This winds me up as they splatter onto 555 if they are strong enough to me. Why the hell dont they move a bit further away? {bnghd}
Rant over :D
5K is plenty of distance. Get better RX.
Tim
Call Sign: 26AT239
Re: 27.560 muppets
Post by Tim » 03 Sep 2017, 13:14
If you have better RX that close to T5 then you don't have a very good antenna.
NightProwler
Call Sign: 163TM186
Re: 27.560 muppets
Post by NightProwler » 03 Sep 2017, 13:43
Im using a Yaesu FT757GXII with an Imax 2000 fed with 15 meters of RG213 not a Fidelity 1000 and a coat hanger :roll:
slamjam
Call Sign: 26DT871
Re: 27.560 muppets
Post by slamjam » 03 Sep 2017, 14:07
Maybe you need a narrow ssb filter for it!
26DT871 - Ipswich UK
speeddemon
Re: 27.560 muppets
Post by speeddemon » 03 Sep 2017, 14:09
:D :wave: :thumbup:
speeddemon
Re: 27.560 muppets
Post by speeddemon » 03 Sep 2017, 14:40
:D :lol: :lol:
NightProwler
Call Sign: 163TM186
Re: 27.560 muppets
Post by NightProwler » 03 Sep 2017, 17:00
I have to say...Whats with all the pictures?
speeddemon
Re: 27.560 muppets
Post by speeddemon » 03 Sep 2017, 17:18
For tm1 members to injoy /for there Amusement.bro cheers n 73's. :D
Call Sign: n0call
Re: 27.560 muppets
Post by ch25 » 03 Sep 2017, 18:02
Selectivity SSB/CW(W)/FSK: 2.7 KHz (-6 dB), 4.5 KHz (-60 dB) is pretty wide nowdays.
Just checked mine rig, pretty old one. 2.3 KHz (-6 dB), 3.3 KHz (-60 dB)
Tim
Call Sign: 26AT239
Re: 27.560 muppets
Post by Tim » 03 Sep 2017, 20:14
You can quote figures all you like, you're going to get splatter from 5kc's either side no matter what the radio is, old or new.
