RG6 coax for cb radio use anygood ???
- WARLOCK
- Call Sign: 26TM134
have just been given loads of RG6 satelite coax would this be any good to use for cb radio,?? Thanks in advance for any replies
- Call Sign: G4RMT
Re: RG6 coax for cb radio use anygood ???
It's low loss, and thin - but a rotten match to 50Ohm systems as It's 75Ohm - in reality, on receive it's not really a problem, but with all the usual grief getting a radio matched to the antenna, using 75Ohm cable makes all the readings your meter provides a bit pointless. A length of RG6 to a 50Ohm dummy load doesn't give you a 1:1 VSWR, which 50Ohm cable will.
- Kaos
