crt 7900
- stanogs68
crt 7900
hi ,i have a 7900 ,i bought it like this ! the channels are all mixed up ,i really am lost ,i have not done it but it needs all the channels back in the right order ,i believe you can do it with the computer but i need a lead and i need a lead and software ,i have looked and it seems to be twenty quid ,gutted any ideas lads ,thanks
love your familly
- Auldgeek
- Call Sign: GM0BRJ
Re: crt 7900
You can do a reset that will default the channels back to factory settings.
In the menu, locate reset and choose reset all.
Auldgeek - Drew
- porky.69
Re: crt 7900
Same has a stryker i had. Now i stick with the older radios lincoln 1. People tend to mess with these new radios because they can. Good luck with the reset matey
This is my Territory.....Be on your way
- prettypolly
- Call Sign: 26FB185
Re: crt 7900
Press
【MENU】for 2 seconds to enter menu list;
Turn Channel switch to select menu No.10;
Press
【PUSH】to enter the menu setup;
Turn channel switch to select wanted setup;
OPT: All function setup resume default;
ALL: All channels and setup resume default;
Default: OPT
Press
Default: OPT
- stanogs68
Re: crt 7900
ill try that,thanksprettypolly wrote:Press
Press
Default: OPT
love your familly
Re: crt 7900
I think you're missing the point with these radios stan, they are supposed to be individualised, obviously one persons idea of a band plan is not anothers.
- stanogs68
Re: crt 7900
admiral ive not misunderstood i ust am lost with technology HELP ,ive reset the channels but im lost ps THANKS Pretty pollyAdmiral wrote:I think you're missing the point with these radios stan, they are supposed to be individualised, obviously one persons idea of a band plan is not anothers.
love your familly
