Anytone AT-5555 dat files for V6
310den
Post by 310den » 13 Apr 2017, 16:07
Had a search through the old threads but no joy. I have the above but the only dat file I have that I want to use is for a V4 which as you know is not compatible.
Is there a way of editing the file to update it? I tried Notepad but it makes the file invalid if you change anything.
The file I had was from on here that someone posted, UK CB on band A then LoLo to HiHi on B upwards. That is what I am after but for a V6 if anyone has one or knows how to edit and update a V4 dat file that would be great.
Thanks.
kilimax
Call Sign: GM0BRJ
Re: Anytone AT-5555 dat files for V6
Post by kilimax » 13 Apr 2017, 16:53
I can provide you with V6 Dat files and you can then edit them to suit.
I'll PM you.
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
310den
Post by 310den » 13 Apr 2017, 17:14
Nice one, just replied. :thumbup:
ghost123uk
Call Sign: 26TM953
Post by ghost123uk » 14 Apr 2017, 07:42
Are the DAT files for the 5555 the same format as the ones for a 6666 I wonder.
My dat file software for my 6666 is V2. I'm guessing it must be different as I cannot find any reference to a version higher than V2 for the 6666.
Post by Admiral » 14 Apr 2017, 08:29
My suggestion would be to have a go yourself, it's so simple even I can do it, and it can be fun, you can then tweak your radio exactly how you want it and not how someone else wants theirs.
310den
Post by 310den » 14 Apr 2017, 09:55
Admiral wrote:My suggestion would be to have a go yourself, it's so simple even I can do it, and it can be fun, you can then tweak your radio exactly how you want it and not how someone else wants theirs.
I could not do it. Not talking about changing frequencies or settings as that is easy but changing version. I used notepad++ and where it shows V100 and the beginning I changed it to V600 but that makes the file invalid so how to you convert a previous file version to a V6 and what do you use to do it?
Post by Admiral » 14 Apr 2017, 10:28
I'm probably getting confused here, just open the V6 software and start again, or copy and paste.
310den
Post by 310den » 14 Apr 2017, 10:30
Admiral wrote:I'm probably getting confused here, just open the V6 software and start again, or copy and paste.
Yes I think crossed wires. Copy and paste is not so easy either unfortunately. Being able to edit an earlier version file to update it to a later one would be good but it's not made to be easy unfortunately. 8)
ghost123uk
Call Sign: 26TM953
Post by ghost123uk » 14 Apr 2017, 20:38
ghost123uk wrote:Are the DAT files for the 5555 the same format as the ones for a 6666 I wonder.
Just to answer my own question = the 5555 software is not the same as the 6666 software and the files are not transferable between models.
14CS06
Post by 14CS06 » 05 Nov 2017, 17:47
Hello
ANYTONE AT-5555 Ver 6 here
https://www.ebay.fr/itm/ANYTONE-AT-5555 ... Sws6ZZ-wBV
