Best Ariel For My Needs
Re: Best Alriel for my needs
Post by P5shn » 22 Feb 2017, 08:50
{bnghd} Well I have brought the venom 5/8 Ariel for the time being and have mounted it on a new 3m heavy duty Ariel pole from screwfix
Also mounted to the pole is my new air and scanner Ariel.
Well here is my new problem, I spent a good couple of hours going through my president Grant 2 last night and never heard anyone on any band,
The swr is good and either 1.1 or 1.5
Is it because the fibreglass top of my scanner Ariel is poking between the 3 radials on my venom 5/8 would this mess with my reception ?
The scanner Ariel has plastic brackets that isolate it from contact with the 3m pole
I am at a loss, I struggle a lot as it is with my health so now I am thinking bugger would I be best taking the scanner Ariel off the 3m pole that the venom cb Ariel is on & would that solve my problem ? Also my scanner coax is running along side for 50ft the length of of my cb coax, both being mini 8 military grade, i don't use the cb & scanner at the same time but there is deffo a problem cus I am getting no one on my Grant 2 & it is a new rig that has had the export mod professionally fitted by the same shop where I brought all my kit.
Any help would be much appreciated.
I will never forget, I will never regret, I will live my life !
Call Sign: 26TM953
Re: Best Ariel For My Needs
Post by ghost123uk » 22 Feb 2017, 09:03
The other antennas will not be causing any problems of that nature. Is it not possible that it was simply dead on air during the time you were testing it. If the SWR is good, all should be fine.
My only concern is that I would FOR SURE disconnect any other receivers from their respective aerials before transmitting on the 11Mtr set.
Reason being, the very high RF field strengths that close to the other aerials could easily wipe out the RF input amplifying semiconductors in the scanner!!
Call Sign: 26AT013
Post by andrew013 » 22 Feb 2017, 21:35
as said in post above swr is perfect more than likley nobody on it does happen
