sadelta
- Call Sign: BPO6O
sadelta
Hi chaps I want to wire my sadelta echo master plus to my alnico 135 have got the cross over cable but need the wireing code had it on the cobra took wire off pin4 plugged it in and it started scanning the radio could any one help thanks
- Mudslinger
Re: sadelta
The Alinco wiring is the same as president 6 pin.
Be careful as the mic socket carries 13v on one of the pins, and if you get the wiring wrong you will damage the mic, radio or both.
- Mudslinger
Re: sadelta
