alinco 135 uk
Tom
Call Sign: BPO6O
alinco 135 uk
Post by Tom » 15 Jan 2017, 15:22
Hi chaps is the Alnico 135 uk is it programed the same as the anytone 555 and can you use the same free program that's on here. :D
kilimax
Call Sign: GM0BRJ
Re: alinco 135 uk
Post by kilimax » 15 Jan 2017, 15:57
Tom wrote:Hi chaps is the Alnico 135 uk is it programed the same as the anytone 555 and can you use the same free program that's on here. :D
It's similar but unlike the 5555, you plug the cable into the mini D type at the back of the radio. Uses a different lead too.
Software is different but again, is simialr in operation.
Software available here:
http://www.cbradio.nl/alinco/alinco_dr-135DX.htm
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
Tom
Call Sign: BPO6O
Re: alinco 135 uk
Post by Tom » 15 Jan 2017, 17:03
Thanks mate
Black Spirit
Re: alinco 135 uk
Post by Black Spirit » 15 Jan 2017, 19:34
If you have a 5555 cable you can use it but you need to remove bottom case.
kilimax
Call Sign: GM0BRJ
Re: alinco 135 uk
Post by kilimax » 15 Jan 2017, 19:42
Black Spirit wrote:If you have a 5555 cable you can use it but you need to remove bottom case.
What he says! :)
Kilimax - Drew
Tom
Call Sign: BPO6O
Re: alinco 135 uk
Post by Tom » 16 Jan 2017, 06:49
Yep got a cable dose not fit the socket at the back. thanks
Black Spirit
Re: alinco 135 uk
Post by Black Spirit » 16 Jan 2017, 19:30
Take the bottom case off, Locate the socket by following the lead from the mini USB socket at the back to the main board, Pull the lead out of the socket [gently] and slot in the 5555 cable.
