Best mag mounted CB Antenna.?
Benny
Post by Benny » 21 Dec 2016, 22:08
In everyone's opinion -what is the best mobile cb antenna ?
QRP Rules OK!
Farty
Re: Best mag mounted CB Antenna.?
Post by Farty » 21 Dec 2016, 22:24
Best in what way?
Benny
Post by Benny » 22 Dec 2016, 01:58
Best in performance.
QRP Rules OK!
ghost123uk
Call Sign: 26TM953
Post by ghost123uk » 22 Dec 2016, 08:53
I was discussing this over on another thread (about summat else, but it got off topic ;) )
imho, 95% of "performance" is simply size. The bigger the better. Obviously an expensive one will be better made and last longer. However, as you are talking Mag Mounts here, we can straight away remove really big stuff like full 1/4 wave whips, Firesticks and centre loaded "Modulators" (and clones) etc from the list.
Folk will no doubt come here and say the Sirio Blueline / 4000 / 5000 are the best, and I am sure they are good, but they are expensive. I was given the heads up one these Sunker Elite Magnetic Antenna. I've never tried one myself, but they get very good reviews and for the price I might well be getting one soon to try.
I also like ones that are not base loaded. I have several here that are helically wound, with much of the coil being concentrated higher up the twig. I find they work well. Guessing because much of the working part of the aerial is higher up than with a base loaded type. The only issue though is that they tend to be stiffer by virtue of the way they have to be constructed, so one has to be careful of tree branches etc. Also need a strong magnet in a 7" base to ensure they don't get blown off when passing a lorry in the opposite direction at speed. I have recently stopped using them on my new car for this reason "just in case".
Mudslinger
Post by Mudslinger » 22 Dec 2016, 10:05
Best value twig on the £ per performance stakes IMO is the original modulator.
I can barely tell any difference between it and the 1/4 wave whip which I have.
Just don't buy a Moonraker magmount from Craplins as they are badly made, and usually have dodgy connections.
Those Sunker antennas look very good value as well, considering you get the magnet included.
Benny
Post by Benny » 22 Dec 2016, 12:34
Great answers lads - thanks!
QRP Rules OK!
ROTEL240
Post by ROTEL240 » 22 Dec 2016, 15:55
As mudslinger says the modulator is the best value for money as good as the sirios, firestick, tankwhips for a fraction of the price, i use a trimag although not cheap it gives a good ground to the antenna and better support so it wont come off the car,the single 7" sirio mounts are very strong,check the fittings of the mounts as there are 2 main types 3/8th and so239...
dt307
Call Sign: 163dt307
Post by dt307 » 22 Dec 2016, 16:51
ml145 by siro is cheap and works great
megawatt 4000 or 5000 better but cost more
163dt307-chris
― Albert Einstein
GaryWilson
Call Sign: 2E0GGQ
Post by GaryWilson » 25 Dec 2016, 10:10
I use a wilson 1000 it gets the job done !
26CT1836 2E0GGQ
porky.69
Post by porky.69 » 25 Dec 2016, 19:26
sirio 4000 antenna is the best one for me :thumbup:
This is my Territory.....Be on your way 8)
Buick Mackane
Post by Buick Mackane » 25 Dec 2016, 19:32
DV-27 mounted on a biscuit tin. Used by thousands of breakers back in the day :thumbup:
Some days will stay a thousand years, Some pass like the flash of a spark, Who knows where all our days go ~ Stuart Adamson.
beamer320i
Post by beamer320i » 25 Dec 2016, 19:37
Sirio 4000 mounted on a Sirio MAG 145 PL Magmount. You'll never need another mobile antenna.
Had mine 14 years now - stayed on at 85MPH when I've forgot it's on the roof, can handle shed loads of power if that's your thing, worked all over the world on it.
ghost123uk
Call Sign: 26TM953
Post by ghost123uk » 26 Dec 2016, 08:43
I've always fancied doing a mobile antenna "shoot out". Get another station 5 miles away to connect up a digital meter to their S meter. Then, obviously using the same rig and car, try out lots of different aerials and note down the reading the other guy is getting on his digital meter.
Now I have done this (back in the day), but we didn't write it down :roll: :oops: We just made a mental note of which one was best, iirc it was a centre loaded "Modulator", but you can't use that on a mag mount!! (unless parked up, DX'ing, which we did often).
porky.69
Post by porky.69 » 26 Dec 2016, 10:11
beamer320i wrote:Sirio 4000 mounted on a Sirio MAG 145 PL Magmount. You'll never need another mobile antenna.
what dom says is bang on. great dx antenna :thumbup:
andrew013
Call Sign: 26AT013
Post by andrew013 » 26 Dec 2016, 10:32
sirio 4000 , 5000 , modulator twin coil original bullwhip , 1/4 wave , scarlet warrior, are the only ones i use apart from a 4 ele yagi and imax when parked up
