Funny 1n4007 diode
- prettypolly
- Call Sign: 26FB185
Funny 1n4007 diode
I've got a funny 1n4007 diode if I test it on the circuit board it's say it's open circuit knackered but when I test it off the circuit board it's reading it's OK ??
Re: Funny 1n4007 diode
Testing components in-circuit is not going to get you anywhere as you won't get correct measurement results.
What meter range are you using for the test?
That's pretty weird . Sometimes the resistance might be higher with it in circuit , but I've never had one measure open . Are the contacts clean on it ?prettypolly wrote:I've got a funny 1n4007 diode if I test it on the circuit board it's say it's open circuit knackered but when I test it off the circuit board it's reading it's OK ??
- prettypolly
its ok i replaced them with super maplins ones not fussed over a 9p diode.
