QRM and lots of it !!!
- Call Sign: 26AT239
Re: QRM and lots of it !!!
Some auto timers such as electricity meters and the like that use the what was known as 'economy 7' system and switch over do so on GMT, now we're going back to GMT these units will in effect kick in an hour earlier from then.
- johnkyrle
- Call Sign: 26TM3375
That is a very good point and one worth checking,thank you,will monitor that and let you knowAdmiral wrote:If it is a heating system then it may start an hour earlier on Sunday as that's the last clock everyone alters.
- johnkyrle
Slightly off topic but saw some of those bloody awful PLT units tonight in Tesco.Reduced to clear!!Wonder why??
- johnkyrle
Could go down the OFCOM route but lot of hassle and they nearly always refer you to the BBC (!) who then refer you back to OFCOMPLL02A wrote:Considering its starting at the same time everyday my money would also be on a heating system kicking in. Have you tried relocating your aerial ? You never know. It might not stop it. But could knock a few S-points off it which could make all the difference. Failing that you've only two options. Get ofcom on the case or get yourself a QRM eliminator.
Good thought though thanks
