Request for circuit diagram for Cobra UK 25 LTD ST CB Radio
Hi to all, Have previously requested service info on the Cobra UK 29 LTD but have had to date had no luck, but as (I am told) the UK 25 LTD ST is similar to the UK 29 LTD ST Model you never know maybe someone has the "25" service information/circuit diagram. On my radio the s/rf meter / swr meter does not function at all and the channel LED is very dull. I think these faults are because the Guy who owned it before me dropped it and some of the very fine copper tracking has gone O/C, it's very fine and very difficult/ impossible to try and trace the tracking through the 3 PCB'S that are all soldered up to one another! Any service information/ circuit diagrams would be most welcome to rectify the 2 faults.....Many thanks to all who read this, and hope someone can help...Dave.
- Tech12
- Call Sign: Sparky
Re: Request for circuit diagram for Cobra UK 25 LTD ST CB Ra
Hi mate: If you look at the front PCB on your 29, where the Ribbon cable attaches at the R/H side. Just in front of the ribbon cable is an SMD transistor Q2 & from the collector of that resistor R10 47R, they control the supply to illuminate the channel display. Can email you a CCT if that's any good to you.
Andy
Andy
Let us Fix it Properly.
- Dragonfly
- Call Sign: 26TM363
- Coppernob
Is it me ,but that right ribbon cable looks melted or someone's been at it with a blowtorch,or summat has seriously overheated !
Regards Coppernob.
- RadioPixie
- Call Sign: 26TM552
Was that you foggyman that PM'ed me in the summer for info? If that was you, sorry I was busy plus I think my diagram isn't good enough to be scanned.
As mentioned the display may be down due to Q2, or even around Q90 and Q91 which are driven by the PLL/Processor chip. But check Q2 first.
Do you happen to know if the circuit diagram required is in the user/instruction manual Foggyman? If so I've got one for the 29 in the loft you can have? It'll take me a while to find it out though, so knowing it has before I spend about an hour finding it out will help
- Otter
- Call Sign: 26TM439
Hi,
I am new to the forum, but I think I have the full service manuals for both radios, I am not sure how I will be able to get a copy to you as the drawing is A3 size. not A4 as the rest of the manual is.
If you can let me know where to send it to I will try to scan what I have & let you have a copy.
- Dragonfly
Post it to Imageshack and put a link on here .
- Call Sign: M1KE
Re: Request for circuit diagram for Cobra UK 25 LTD ST CB Radio
I'm also looking for a service manual for a UK 29 LTD. Does anyone have one ?
Okay, found it https://downloads.cobra.com/CB/Models/2 ... manual.pdf
could not get your link to work. see if this one does.
http://downloads.cobra.com/CB/Models/29 ... manual.pdf
