RM KL 203 Transistors
163TM847
Post by 163TM847 »
There isnt anything printed on them and diagram just states MOS RM3, Will IRF520's work ?
Clint
Call Sign: 26TM360
Re: RM KL 203 Transistors
Post by Clint »
Yes, I am sure in fact they are the same.
26-TM-360
Old 80's Radios and lots of them - Vintage Computers especially late 70's C=PETS :)
UGLY_BOB
Post by UGLY_BOB »
Black Spirit wrote:Will IRF520's work ?
Yup... Been there... done that. ;) :lol: :lol: :lol:
Ugs
EXTREMELY WEIRD... AVOID AT ALL COSTS !
163TM847
Post by 163TM847 »
Cheers :D
Ashtec
Call Sign: M6LTD
Post by Ashtec »
Yep IRF520N's work but they do run a bit hotter!!!!!!!
bigpimp347
Post by bigpimp347 »
IRF520N is the higher power/voltage device so better than non N.
or MS1307 is the other, i run nine in a B400 not as good as original (must be re baged IRF's)
163TM847
Post by 163TM847 »
I replaced them and with 5w in [FM] i get 50w out.
The four i removed had all gone dead short :shock:
Cyclops
Post by Cyclops »
IRF520 will work but will be down on power. I needed a replacement for a RM3 and used a Fairchild mosfet, I will look at work tomorrow for the part number. there was about £1 each from rs and 1 in a kl35 does just shy of 40watts, IRF520 in the kl35 did around 15watts.
The shack on a very rare good day http://www.m0gwr.co.uk
Our little team running a special event station http://www.om3kwt.net/gb0gcr/
163TM847
Post by 163TM847 »
ahhhh i just checked the batch of 520's i used and they are non N so i will whip them out and put 520N's in instead.
Cyclops
Post by Cyclops »
Nick this are what i have used in place of the RM3 and they work very well, much better than IRF520 or 520N
http://uk.rs-online.com/web/p/mosfet-tr ... 4E4F4E4526
Ashtec
Call Sign: M6LTD
Post by Ashtec »
Black Spirit wrote:I replaced them and with 5w in [FM] i get 50w out.
Sound's about right to me with 10watt you sould see 80 90 may be the ton!!!
163TM847
Post by 163TM847 »
I havnt replaced them for non N yet, but with the ones in there i get 80w with 10w in but SWR goes right up even on dummyload...So they are not working that well, I have chucked it in the drawer for now and will probably replace them for 520N when and if i can be bothered :lol:
Ashtec
Call Sign: M6LTD
Post by Ashtec »
Black Spirit wrote:I havnt replaced them for non N yet, but with the ones in there i get 80w with 10w in but SWR goes right up even on dummyload...So they are not working that well, I have chucked it in the drawer for now and will probably replace them for 520N when and if i can be bothered :lol:
If it gos for sale i will have it off ya!!!!!!!!
I could all ways use it in the car............
jimtylee
Post by jimtylee »
Clint wrote:Yes, I am sure in fact they are the same.
Hi,
Is the irf520n a direct replacement for the original MOS RM3 DEVICE....IE are the lead out pins the same
my amplifier is the KL 203.....
THANKS
JIM...........
jimtylee
Post by jimtylee »
Ashtec wrote:Yep IRF520N's work but they do run a bit hotter!!!!!!!
Hi,
Is the IRF 520N PIN OUT THE SAME AS THE MOS RM3 DEVICE AS I NEED TO CHANGE ALL FOUR
all short circuit
thanks
jim
