Desperately required
I am desperately looking for anywhere that would sell parts for my anytone AT5555 or any of the clones of this radio
I dropped the rig the other day which resulted in bending the on/off volume/squelch knob and after bending it back it broke the squelch part and now it the knob just spins around without stopping , resulting in the rig being permanenty squelched up
I have tried truck king , knights, thunderpole and cobraworx and none of these stock parts or know of anywhere where I would be able to get the part I need
All help is gratefully received
26-TM-652
- t140pete
Re: Desperately required
Check if the values are stamped or printed on the reverse of the component - I'm guessing there's a good chance it's the same as a Superstar 3900 (both 50K) but I'm sure someone on here will know for certain.
26 TM 349
- bigpimp347
if the squelch (the outer) just spins, this is usually just the tabs that hold the control together coming loose..
you can usually re press these to make the control work right again..
i have had superstars and cobras like this and it's just a simple control come loose senario..
failing that if they are standard controls then superstar ones will work, if they are soldered direct to a board type, you might be shafted..!!
- Adriano9966
perhaps I am stating the obvious but have you tried the manufacturer
perhaps they could repair it or even send out replacement parts
hope this helps you
http://hengringtai.en.alibaba.com/
hope this helps you
I wouldn't expect to get the parts from the manufacturer unless you really don't know what they are and want to pay the premium.
Are they not just everyday parts? Whip it out and stick your meter on it, the track should still be intact. Although as bp says, by the time it's out you will probably fix it.
Bigpimp , Do you know your way around a cb? If so do you fancy taking a look at it for me , Im only down the road from you
Ive taken it apart as much as i dare and still cant see any numbers that relate to the part
26-TM-652
just had info off Hans today that this part is not available as yet but a control switch off a midland alan excel wil do the job although the knob is not the same
Does anyone have one of these rigs lying around?
http://www.alan-uk.com/cb/products_cbra ... ulti.shtml
26-TM-652
- George EI7KO
- Call Sign: EI7KO
It's a pretty poor state of affairs that none of them that are flogging the life out of them do no carry spares. Does it bolt to the inner front plate or is it a pcb mount control? (these bolt to front plate too though)
BLUE LED'S ARE BEST!!!!
- UGLY_BOB
A photo of the damaged one might jog peoples recognition, and get them thinking of alternatives.
EXTREMELY WEIRD... AVOID AT ALL COSTS !
- Sylad
Check your PM Gaz W
Simon
Lincolnshire
26TM158 & 26DX617
INDEED YOU ARE POWERFUL !
Lincolnshire
26TM158 & 26DX617
Should we give up answering, Or look up the midland to see what he needs? Just why are you telling us you have pm'd him?Sylad wrote:Check your PM Gaz W
Sorry about that , yes you can stop looking for the midlandfriendly1uk wrote:Should we give up answering, Or look up the midland to see what he needs? Just why are you telling us you have pm'd him?Sylad wrote:Check your PM Gaz W
I now have the parts I need to fix the radio , a massive thanks goes to sylad fir sourcing me the part and sending them to me free of charge
The radio is now with someone being fixed
If any of you lot do own a anytone AT-5555 my advice is be very careful with it as parts are near impossible to get , even hans in Germany cannot get any parts for the radio
26-TM-652
Gaz W wrote:Sorry about that , yes you can stop looking for the midlandfriendly1uk wrote:Should we give up answering, Or look up the midland to see what he needs? Just why are you telling us you have pm'd him?Sylad wrote:Check your PM Gaz W
Congratulations Gary and Well Done Sylad !
its good to hear that there are still some good souls out there
hope to hear you on air sometime gaz
- Ashtec
- Call Sign: M6LTD
Yes post a pic i may have a pot or two that will do the job.............
- UGLY_BOB
It's all sorted Paul. He got the part, and it's away being fixed.
