Icom 706 extended tx
MrWeetabix
Call Sign: 26TM175
Re: Icom 706 extended tx
Post by MrWeetabix » 14 Sep 2017, 15:38
Ah I remember now. The lad lived in the flats..... Yeah, I didn;t keep the George long either.
I regretted letting my mate have my 2nd 706MK2..... recently begged him to get it back, and did. Brilliant little radios! I have one in the car and one in the shack. So versatile!
I tried the 7000, but I didn't like how hot it used to get, even just sat on RX. It just put me right off.
astradyne
Post by astradyne » 14 Sep 2017, 16:08
I upgraded to a MK2-G and it's an excellent radio. The coverage is beyond belief on these things.
tenrohle
Post by tenrohle » 14 Sep 2017, 19:40
I wish mine would tx on 11m! :(
astradyne
Post by astradyne » 15 Sep 2017, 09:22
tenrohle wrote:I wish mine would tx on 11m! :(
Did you reset the CPU after removing the diode?
MrWeetabix
Call Sign: 26TM175
Post by MrWeetabix » 15 Sep 2017, 11:12
who advised you to 'crush' the diode?
tenrohle
Post by tenrohle » 15 Sep 2017, 19:29
astradyne : yes a couple of times
mrweetabix : there is a couple of ways of doing it, and thats one. sounds all wrong I know!
"The second diode from the left needs to be removed. I did this by crushing it with long-nosed pliers. You can also heat it with a low-wattage soldering iron and pull it up with tweezers. Be sure not to damage the other diodes or the PCB. Be sure that you don't apply too much heat, since the heat can damage the PCB and the other diodes."
The diode itself is about 2mm in size so removing it would require me purchasing a tiny soldering iron, a magnifying glass and some tweezers.
Is there a chance that the remaining feet are the problem?
lu9erb
Call Sign: Lu9erb
Post by lu9erb » 12 Jan 2019, 14:09
Hola colega ..consulta ..tengo el mismo problema que usted ... tambien mi Icom 706 No trae el diodo D59 ! .. y no se como liberarlo ...para poder transmitir arriba de los 148 mhz ..?? ... usted encontro alguna solucion ? .. se lo agradeceria ... 73 ..de jose LU9ERB
Hello colleague ... check ... I have the same problem as you ... also my Icom 706 Does not bring the diode D59! .. and I do not know how to release it ... to be able to transmit above 148 mhz .. ?? ... you found some solution? .. I would appreciate ... 73 ..de jose LU9ERB
