valve's for a linear amp uk ranger 811A
- Ashtec
- Call Sign: M6LTD
Where can i get some valve's for a linear amp uk ranger 811A as ive melted the old one's in a day so im on the look out for some to put back in it.
I did ring uk amp's up and they whant £49each and there is 4 of them to replace SO IM LOOKING AT £200+ to replace them but i was told i can get them for about £18-20 each but i can not fined them on the net at all for that ive only had the amp for about 2 day's
It's just not my week this week..................................
- bigpimp347
Re: valve's for a linear amp uk ranger 811A
bloody CBers..stick with zetagi's paul, at least you could build a brick shithouse with the blown ones..!!
do a search on ebay for them, worldwide, you may find them in the ukraine or similar.
- Ashtec
- Call Sign: M6LTD
bigpimp347 wrote:bloody CBers..stick with zetagi's paul, at least you could build a brick sh*t with the blown ones..!!
I will try ebay again if not another amp will have to be put in it's place.........................................
- gmham
- Call Sign: 108TM154
Had a ranger 811a myself mate and did not find the valves very forgiving !! ended up getting shot off it and picked up a lovely excellently built semi homebrew valve amp running a pair off 813`s much more forgiving in the tuning dept !!
picked up one off these pulse tuners an although I have not used it yet supposdly makes tuning up a doddle and much safer !!
as mark says sure russia is the cheap source off valves these days ??
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
replace the 811's with 572's, you'll not blow them up in a hurry.
straight swap too!
there's plenty of 572's on the 'bay.
my 2x572 FL2100z will keep up with your 3x811 ranger, and I haven't managed to break that yet!
straight swap too!
matched quad of 811's are listed at $89 from rf-parts
W8JI
- STARSHIP
- Call Sign: M3PIE
I have a linear amp uk, ranger 811h with Russian 811 valves in it.
they have been in use since 2004 with no trouble.
73
mark.
73
mark.
Yaesu FT-990, Ranger 811h.
- Unit 148 Mobile
- Call Sign: G4ZOW
Ash,
How much power were you using to tune the amp up?
You should be using half of your transceivers power IE 50W.
Unit 148 Mobile
Unit 148 Mobile
- cb4ever104
This thread was started 8 years ago m8 . Paul , Ashtec , isn't around much these days .
