Hi , I have just aquired a President Lincoln 2 V3 ...or I was told it is a V3, it did not come with a box , so how can I tell if it really is a V3 ?
President Lincoln 2 V3, or is it?
26-TM-652
Re: President Lincoln 2 V3, or is it?
Does the radio have a serial number on the back,if it does.........google it with Lincoln2 CB serial numbers
Freebanders happen to know otherwise = test free.
27.555 Usb
27.555 Usb
- ballo
- Call Sign: 19DD03
The v3 is the Lincoln 2 and the Lincoln 2+ is the v4 , you can see it on the front.
Lincoln 2 v3 : https://www.communicationworld.nl/presi ... oln-2.html
Lincoln 2+ v4 : https://www.truckerswereld.nl/president ... n-ii-plus/
http://www.pa3hgt.nl
President Veep 40 ch am/fm , President Jackson Classic 6 bander , CRT SS9900 , President Lincoln 2+, RM HLA 300V+ met Sirio Turbo 5000.
^^The version 3 didn't have V3 on the front of the radio Ballo just Lincoln 11,he also never got the cardboard box it was sold in which had V3 on the box = if you want to be sure Gaz W........open up the radio and check the main pcb code ^^
27.555 Usb
27.555 Usb
Users browsing this forum: Google [Bot] and 5 guests
