Exeter Frequencies
Scanning radio frequencies for the South West
exemacs
Call Sign: exemaccs
Exeter Frequencies
Post by exemacs » 03 Dec 2012, 16:32
Hello.
I have just found a realistic pro -2006 scanner in the loft and after many years of non use, The last time I used it was over 15 years ago when I used to use it to listen to the police and other services… I appreciate that these have now gone digitally encrypted and I won’t be able to listen to these frequencies any longer. My question is, Are there any known frequencies that I can manually enter into the scanner, I have done a scan in the NFM band and most of what I picked up seemed to be repeaters or just ‘noise’. I used the link on this forum that gives a list of frequencies but again I did not get anything. I live in Exeter. Does anyone have any frequencies I can use ? Im just learning how to use the scanner again as the last time I used it I was 15 year’s old… and now being 31 I’ve forgotten how to use it correctly. When using it 15 years ago all the frequencies were already programmed in, But now the battery has died I have nothing programmed… Just looking for a bit of help if you wouldn’t mind.
Exemacs
exemacs
Call Sign: exemaccs
Re: Exeter Frequencies
Post by exemacs » 06 Dec 2012, 19:14
Anyone ? Appreciate that I'm not going to get any secrets...
superdave
Call Sign: M6JXP
Post by superdave » 06 Dec 2012, 20:22
I don't know any frequencies for Exeter unfortunately but a good place to start is the Ofcom wireless telegraphy register. http://spectruminfo.ofcom.org.uk/spectrumInfo/licences
There you can find the frequencies of most licensed business radio users in the area.
pterodaktyl
Post by pterodaktyl » 08 Dec 2012, 00:16
Have a listen on the Exeter Airport frequencies (AM):
119.800MHz - Tower
123.575MHz - Radar
128.975MHz - Approach
119.325 - ATIS
Minus1
Post by Minus1 » 09 Dec 2012, 08:59
Exeter airport also reported to use
446.17500
446.25000
if you're close enough
124.15000 AM Plymouth Military (East of Berry Head)
I think this trunked net is in/near Exeter
177.56250 NFM Devon County Council 185.5625
177.82500 NFM Devon County Council 185.825
178.05000 NFM Devon County Council 186.05
178.22500 NFM Devon County Council 186.225
exemacs
Call Sign: exemaccs
Post by exemacs » 21 Dec 2012, 20:01
Chris64ex4
Post by Chris64ex4 » 30 Dec 2012, 20:53
Minus1 wrote:Exeter airport also reported to use
446.17500
446.25000
Exeter airport also uses 459.5750 and 459.900 Mhz as well.
Exeter St Davids station = 453.900 Mhz (base) 460.400 Mhz (mobile) (118.8hz CTSS)
Exeter rail depot radios = 462.075 Mhz (simplex)
Stagecoach buses have gone digital, no longer active on Band III VHF. Railway cab radios on Band III VHF shut down as of 05:00 tomorrow morning.
Various users on 449.3125 & 449.4750 Mhz.
Fairly sure the shopwatch / pubwatch has gone digital. Used to be on 453.975 Mhz, been unable to find it for some time.
pmr446man
Post by pmr446man » 02 Jan 2013, 20:17
the 449 channels are uk general
pmr446 king.
