Mobiles are 4.8 mHz higher up on that band (165 - 169)
166.1 will be paired with 170.9.
There are also uhf channels which are more localised, and from what I gather, cut out the data chatter.
If you look in the Andrew's AR file (in the Scotland 'room') and scroll down you will see all six in I think bank C.
You will have to listen out to see which is used locally in your area.
When I update it later this month (not a lot left, granted) I'll put it in the Members lounge instead. Most of the frequencies are from around here (Ayrshire) but with a smidge of area's I haunt frequently too.
Need help on a freq
- Banned
