TYT MD-380 Codeplug help
brew_dog
Post by brew_dog » 11 Dec 2017, 17:25
Hi
Looking for a codeplug/s for the tyt md 380
For Edinburgh and Fife Areas
Ham / pmr / dmr / pubwatch / shopwatch etc
GD-77
Mototrbo dp4800
Hytera PD785
Hytera PD505
TYT MD380
listner132
Re: TYT MD-380 Codeplug help
Post by listner132 » 17 Dec 2017, 13:19
Unfortunatly fella its not just as simple as that..code plugs take time to make upfor your area..yes they are some generic code plugs from the net but these have to be fettled around with to suit your area.
hope this helps.
GuidesH
Call Sign: MM6OYJ
Post by GuidesH » 03 May 2018, 08:09
Im new but been fiddling a while, most cctv/pubwatch are on NXDN which ive not found a firmware for on the tyt 380, but pmr is analog and only needs the rx/tx frequency on and dmr/pmr is tg 99 cc1 hope that helps, there are firmware out there that can scan tgs but cant tx
MTH800
SRH3800
TYT-TH-9800
AILUNCE HD1
GD-77
Metradio
Call Sign: G7HID
Post by Metradio » 03 May 2018, 15:01
Round the country most Shopwatch/CCTV/Pubwatch systems who have migrated to DMR, hardly anything has migrated to NXDN.
The TYT380 will never be able to do NXDN as NXDN uses Frequency Divided slots and the 380 being DMR uses Time Divided slots..
Mike
GuidesH
Call Sign: MM6OYJ
Post by GuidesH » 03 May 2018, 21:53
Ok thank you metradio for the info on the TYT, it is always good to learn things. Regarding NXDN I know Aberdeen is on NXDN48 and some other Scottish towns but maby most are DMR and I appologise for broad stroaking.
MTH800
SRH3800
TYT-TH-9800
AILUNCE HD1
GD-77
Metradio
Call Sign: G7HID
Post by Metradio » 04 May 2018, 10:32
No need to appologise, you are seeing what is happening local to you and expect the same to be happening all over the country.
It is only when you speak to others from other parts then you get a clearer picture..
Mike
