new community fm station glasgow
- radioenthusiast2011
Camglen Radio currently doing test transmissions on 107.9MHz.
They have a 5 year community licence from ofcom.
Coverage of Rutherglen and Cambuslang and probably surrounding areas.Assume they will be using max power of 25watts?
Re: new community fm station glasgow
Yea picking it up in Uddingston no problem.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- kr0ne
- B5566
What's wrong? Pretty much the end of the fm bc.
Resistance is futile.
- kr0ne
Just unusual... It's literally the last stop on the FM dial.
I guess it's less of a deal with these very low power, short term licenses.
Most community, but not all, are either at one end or the other of the Fm band, from 88 - 106 is usually BBC national or the bigger local radio station operators.
- kr0ne
Actually, there are quite a few within 88-108 although RSLs on 87.7 are very common...
Allocations are usually at least 0.2 away from the band edges for obvious reasons though. There are exceptions but they are very rare, at least from what I have seen...
- kr0ne
CR licences:
http://www.ofcom.org.uk/static/radiolic ... y-main.htm
RSL licences:
http://www.ofcom.org.uk/static/radiolic ... d-list.htm
Incidentally, does anyone know how to search for these by frequency across all license types?
RSL licences:
Listening to 107.9mhz signal on standard car tuner with standard whip on roof.
Started losing signal around Haggs on M80 while travelling north.
Pretty good signal up until then!
Heres a wee pic of some of the transmission gear that Camglen radio are putting to use!
Think this might be the Broadcast Warehouse transmitter TX50 (turned down of course!) series with rds and limiter.
heading from south neck of the woods,i started picking 107.9 up near the Viridor site in Strathaven while heading towards east kilbride.
