Amazon in Dunfermline
Hi
Have just had a look on Ofcom WTR and here is the licence for Amazon.
http://spectruminfo.ofcom.org.uk/spectr ... ubmit=Find licence
All freqs listed are MOTOTRBO and are on a Capacity Plus system. I never knew that Ofcom gives you the colour code? This is very handy when trying to decode MOTOTRBO.
Whistler TRX-1
Re: Amazon in Dunfermline
Link might not work so if you want to have a look it's Licence 0930775
Whistler TRX-1
yea I noticed the capacity plus control channel bursts when I was over that way a few times, but to note I have seen licences with the colour code listed but it turns out to be wrong. so may not be the correct one being used.
If you get some info on it can you mail me it so I can programme the radio up thanks.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- kr0ne
Here you go, clicky clicky: http://spectruminfo.ofcom.org.uk/spectr ... nd+licence
Will do Scott i have a few others too that i will send you.
Whistler TRX-1
kr0ne wrote:Here you go, clicky clicky: http://spectruminfo.ofcom.org.uk/spectr ... nd+licence
Yea was already aware of that. But as I said sometimes it's a different colour code from what's listed and that doesn't give group codes etc in use. Hence the reason I asked if any info obtained could be passed over.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- kr0ne
Was just posting a working link so the next person doesn't have to copy and paste the licence number...
- radioenthusiast2011
Just for those interested
Amazon UK in Gourouck
TX: 461.3875 MHz
RX: 461.3875 MHz
TX: 461.3875 MHz
RX: 461.3875 MHz
Receiving Mototrbo signal on 456.375 cc7 slot1
Talk about 18tonner,cages and bays.
A check on the register shows up Amazon UK.the licence number being different from the one previously mentioned in this post.see licence 0953980 this having a newer start date of 2013 than the 0930775 one.
safe to say this is amazon in dunfermline? the only other depot i know is in Gourouck which is too far away.
There is a few users with this frequency, the one you have got with cc7 is the co-op distribution centre in newhouse just at jct6 off the M8 motorway
slot 1 and 2 in use with tg100 and tg200 in use.
never that interesting but good to work out who is using it.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
