Rutherglen shopwatch pubwatch
- radioenthusiast2011
Anyone have the Rutherglen shopwatch pubwatch frequency? I have one think around 456mhz,but dont have it to hand and a search on here didn't come up with anything.
Re: Rutherglen shopwatch pubwatch
ofcom shows as 456.7000, there is a user on trbo on that frequency also but it is a housing association over in the other end of glasgow so if you here the trbo noise dont panic.
hamilton is still analog so i would assume other areas in south lanarkshire are analog also
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
