I will start a new topic on this, the baton is working its way round Scotland, from a photo in the paper today it looks like there is security with radio comms with it.
Anyone had any luck with any transmissions when it's passed through there area?
Queens baton relay
Queens baton relay
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- Call Sign: tm1965
Re: Queens baton relay
the baton is in rutherglen today (22/6/2014) but dont know what channel it`s on yet.
Mototrbo for the games staff with the baton,
168.4625 mobile repeater, digi grp200 and slot 1 for channel 1, possibly slot 2 for channel 2 as that was mentioned that once the repeater is turned off then comms will be lost on channels 1 and 2, but use channel 5 for evening comms, so I assume that will be simplex, not sure if it will be the repeater input or output frequency channel 5 is or if it's different again.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- Call Sign: tm1965
thanks scottyboy will try to listen out.
