Prison on 465.450
Prison on 465.450
From a vantage point in Kilwinning I'm getting a prison or similar on 465.450, talkthrough off, no tone with it. They are using the callsign 'Juliet'. Any ideas where I was hearing. I was lead to believe prisons went non analogue a while ago.
- toby
- Call Sign: 513
- thelad
Re: Prison on 465.450
some are analogue still.DuncanM wrote:From a vantage point in Kilwinning I'm getting a prison or similar on 465.450, talkthrough off, no tone with it. They are using the callsign 'Juliet'. Any ideas where I was hearing. I was lead to believe prisons went non analogue a while ago.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
I know Bowhouse was 446.400, I heard it before it went off there. It's the first prison I've heard in a while. The next nearest to me is Greenock, but I think the lie of the land will stop me hearing that one if it's still analogue.
- thelad
try around the 451 mhz area.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
As far as I'm aware Greenock is tetra, not on airwave but on a tetra system using 454mhz area for the base station.DuncanM wrote:I know Bowhouse was 446.400, I heard it before it went off there. It's the first prison I've heard in a while. The next nearest to me is Greenock, but I think the lie of the land will stop me hearing that one if it's still analogue.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
465.450 will have a pairing of 451.450, if it's like Bowhouse only the base will be heard as talk through was off. I was thinking Dungavel earlier, not a prison but a detention centre. It's in Strathaven.
this is definatly immigration at dungavel 465.450 is the base not picked up the other 8 to 12 channels yet sadly
