Chester Shopwatch (DMR)
Scanning radio frequencies for the North West
FakeJake
Call Sign: 2E0SEY
Post by FakeJake » 07 Feb 2017, 13:00
When searching for the frequency for this shopwatch, i find 4 of them!
Anyone know which I need? Maybe all 4?
Anyone also have the CC and TGs? I have promiscuous mode on and both slots and all CCs set to scan but I haven't had much luck.
Thanks in advance
Jake
Monitoring 2m simplex, GB3CR & GB7HM(DMR)
LeakyFeeder
Re: Chester Shopwatch (DMR)
Post by LeakyFeeder » 08 Feb 2017, 21:27
Im over to see my other half tomoro so will take the lappy SDR an see if i can get the info...its a tad deaf though so might need to be within a spit of a tx site
FakeJake
Call Sign: 2E0SEY
Post by FakeJake » 09 Feb 2017, 11:30
Cheers. I have an RTLSDR but it fails to pick up anything with my indoor antenna.
Jake
hawkeye63
Post by hawkeye63 » 10 Mar 2017, 14:25
Any luck on this?
I have frequencies 440.475, 440.475, 441.0375 and 441.2375, I am visiting Chester soon I could take DSD+ , netbook and scanner but prefer to remain inconspicuous and go prepared if possible.
Can anyone PM me colour codes and talkgoups or a code plug for Retvis RT3 ?
Pete
South Staffordshire
danny1990
Post by danny1990 » 10 Mar 2017, 19:45
You can easily find the CC from your radio with the experimental firmware installed. Just wait for RX then Menu -> Program Radio -> Color Code and keep changing the colour code while there is RX leave a pause to allow the radio to sync, Make sure promiscuous mode is on otherwise you won't hear audio if you don't have the right talkgroup programmed also try changing timeslot. It's slow but useful while out and about.
Not all channels are voice some are data only or mixed.
hawkeye63
Post by hawkeye63 » 10 Mar 2017, 23:28
Thanks for the info , I have been reluctant so far to install the experimental firmware, but if it's worth it i'll do it.
thelad
Post by thelad » 11 Mar 2017, 08:15
Or just save them all into a zone with the CC and Slots and then scan away.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
