446.540mhz
The Pea Launcher
446.540mhz
Post by The Pea Launcher » 05 Jul 2016, 15:23
I'm located in Stockport and this frequency appears to be an uplink of some kind for a local radio station.
Perhaps its either Radio Manchester or Revolution Radio, worth a check out let me know if you can hear it.
Received it on my Baofeng and on my big scanner very strong signal.
moj
Re: 446.540mhz
Post by moj » 05 Jul 2016, 15:53
Yep its revolution 97.2 , its been transmitting on there for a a few months now and has a powerful signal to me aswell ;)
AshtonMobileScanner
Call Sign: 26TM931
Re: 446.540mhz
Post by AshtonMobileScanner » 06 Jul 2016, 00:39
I get the same here aswell its on 446.5375
Motorola UHF DP3600 x2,
Golden One 1907,
Baofeng UV5RA+,
Diamond RH771 Antenna,
UHF Stubby Antenna,
Diamond X-30 Antenna,
MASS SPS 250 MK2.
(Monitor All Channels)
DistantSignal
Re: 446.540mhz
Post by DistantSignal » 06 Jul 2016, 10:28
How come it's on this frequency?
moj
Re: 446.540mhz
Post by moj » 06 Jul 2016, 17:41
I think its the radio mics cause you hear them setting up at there locations first thing in the morning usually, strange tho hearing it so clear and strong
AshtonMobileScanner
Call Sign: 26TM931
Re: 446.540mhz
Post by AshtonMobileScanner » 06 Jul 2016, 23:15
What time do they set up at moj
Golden One 1907,
Baofeng UV5RA+,
UHF Stubby Antenna,
MASS SPS 250 MK2.
The Pea Launcher
Re: 446.540mhz
Post by The Pea Launcher » 07 Jul 2016, 16:24
Its very strong but not heard any setting up, just sounds like a radio station. Can hear it on my boafeng
put my Icom on and signal is 20++
DistantSignal
Re: 446.540mhz
Post by DistantSignal » 07 Jul 2016, 21:58
Gonna listen out tomorrow morning and record it, see what they say rogerrrrrrrrrr
DistantSignal
Re: 446.540mhz
Post by DistantSignal » 07 Jul 2016, 22:31
porkpiehat
Re: 446.540mhz
Post by porkpiehat » 09 Jul 2016, 21:30
Can hear the uplink here in mid Cheshire as well. Some fading but still ok on baofeng uv5r plus Nagoya na-771
73's Rob, 26-TM-531
Sharp 2460
General Electric 3-5805B
Baofeng UV-5R+
Fairmate HP 2000
RTL - SDR
Minus1
Re: 446.540mhz
Post by Minus1 » 10 Jul 2016, 09:52
moj wrote:Yep its revolution 97.2 , its been transmitting on there for a a few months now and has a powerful signal to me aswell ;)
96.2 FFS
http://www.therevolution962.com
Minus1
Re: 446.540mhz
Post by Minus1 » 10 Jul 2016, 09:54
Didn't post.
Then it posted twice.
Now I can't delete the other one!
Minus1
Re: 446.540mhz
Post by Minus1 » 10 Jul 2016, 09:59
DistantSignal wrote:How come it's on this frequency?
The band 446.425 to 447.50625 is allocated to PMSE.
Sadly most of the info about this has now gone behind a logon requirement on the OFCOM website.
So much for openness {bnghd}
mattdcooley
Re: 446.540mhz
Post by mattdcooley » 10 Jul 2016, 18:51
Found this a few months back just didn't post it. Very strong in Trafford also. Never heard setting up just a relay of 96.2 which is weak over there as its a local station to Oldham... They get out better on UHF lol
Re: 446.540mhz
Post by paulears » 10 Jul 2016, 20:08
These links can be in several bands, 48-52MHz, 199.7MHz, 440-790MHz, and 1.5GHz.
440 - 470 MHz
Once you log in with your license details, OFCOM present you with an application form which wants your equipment details in advance, if you already have it available, and then they allocate you a channel. In this case it's interesting as the power is usually quite low.
OFCOM say
Due to the complex pattern of assignments already made in these bands, a bandplan is not available. Users will be advised of possible frequencies upon application.
Available at 12k5, 25k0 and 50k0 bandwidths. The fees are set in multiples of 48hrs.
They're supposed to be links, although there is another possibility - the quality of that clip posted on youtube is band limited - as in comms quality, so it's possible it's being used as talkback for an OB? I don't know if they do this, but on an OB you want an analogue feed to the OB so they can use it for cueing purposes, and knowing when they're off-air. Quality is unimportant. They could simply have forgotten to turn it off! The fact so many can hear it means it's an omni signal, or just that everyone is one the bearing of the link which is unlikely. Talkback feeds also come under PMSE. If you don't have a log in you can't access much of the information, and to be honest, apart from booking frequencies when you need more, it's not that interesting - as much is manually coordinated by real people on receipt of a completed form in word format. Your license type also allows users to only do certain things - so while I can book extra radio mic frequencies, I can't book a link, and I believe that people who hire out radio systems (like me) don't get access to people with fixed site licenses.
Not sure if this helps - but I'd strongly suspect human error here.
