Hi Everyone,
Just found this wonderful forum i am located in Stockport and listen through
a YUPITERU MVT 7100 and a long wire.. and a YAESU FRG 7 on a 1/2 G5RV
Just wondered if you guys could point me in the direction of some interesting scanner frequency's
in the Stockport area.
Particularly interested in finding services between 150-170mhz and not sure what mode to use.
Listener From Stockport
- ThePeaLauncher
Re: Listener From Stockport
Hello and welcome.
Don't have any advice with regard to frequencies but check here:
http://spectruminfo.ofcom.org.uk/spectrumInfo/licences
If you haven't already done so.
Ham: Yaesu FT-100D, Yaesu FC-20.
CB: KPO DX 5000(V4), TTI-TCB-880.
Scanner: Uniden Bearcat UBC 3500XLT, Alinco DJ-X3, Yupiteru MVT-7100.
PMR 446: Binatone Terrain 550.
26-TM-2407
26-TM-2407
- Call Sign: redacted
Almost everything between 150-170MHz will be FM and 12.5kHz channel spacing.ThePeaLauncher wrote: Just wondered if you guys could point me in the direction of some interesting scanner frequency's
Set your 7100 to do an edge search and run it regularly. Note any active freqs and when they are active so you can program them in for more extended listening and identification.
Do the same with other chunks of the spectrum too.
You'll develop your own list of ACTIVE LOCAL frequencies - Far better than relying on the often out of date lists that people (with the best of intentions) keep posting on the internet.
