Hi,
Does anyone know if there are any marine frequencies receivable in Billingham or am I too far in land to hear that? I have got Tees VTS (156.700) programmed in and that is clear but is there any other marine frequencies available? Also I have 164.7375 programmed in and labelled "Taxi", does anyone else hear this?
Any Marine frequencies receivable in Billingham?
- jackbromby
Re: Any Marine frequencies receivable in Billingham?
I get Tees VTS from the back end of Boro and a few others toojackbromby wrote:Hi,
Best thing to do is program in all VHF marine freqs and keep the channels with comms on and ditch the dead ones, I`m not by a radio at the mo so I cant help you out with freqs
You should get all sorts from Billingham but it'll depend on the antenna you are using
26TM234
- dcwuk
Go to the link and scroll down to the bottom of the page you will then see links to
Marine,shop and pubwatch frequencies.
Most of the marine channels apply to the whole of the UK especially channel 16 (156.800)
http://www.radiouser.co.uk/
Acknowledgements to Bill Robertson and Robert Connolly of Radiouser
Magazine
hope that helps but as smoggy07 depends upon your set-up?
cheers
dcw
Magazine
cheers
dcw
- jackbromby
Thanks for the link. I'll check that out and I'll program Ch 16 in as you said. With regards to my setup I am using a handheld Uniden USC230, so maybe not the best but I have both Billingham Shopwatch and Stockton Shopwatch which my radio picks up fine. Tees VTS is also very clear in my house.
You must be near Mill Lane or Central Ave to be getting stockton shopwatch, I could only just to say get it near the Telstar lololjackbromby wrote:Thanks for the link. I'll check that out and I'll program Ch 16 in as you said. With regards to my setup I am using a handheld Uniden USC230, so maybe not the best but I have both Billingham Shopwatch and Stockton Shopwatch which my radio picks up fine. Tees VTS is also very clear in my house.
You should get quite a bit in Billingham with all the chemical sites and the like over that way plus you should get a bit from Boro too where you are
26TM234
- jackbromby
I'm near Pentland Avenue, Stockton Shopwatch is very weak but listenable. I have a TV antenna on the roof of my house, which I have connected to my radio for FM signals. I might see if I can find a way to connect it to my scanner, should get quite alot then.smoggy07 wrote:You must be near Mill Lane or Central Ave to be getting stockton shopwatch, I could only just to say get it near the Telstar lololjackbromby wrote:Thanks for the link. I'll check that out and I'll program Ch 16 in as you said. With regards to my setup I am using a handheld Uniden USC230, so maybe not the best but I have both Billingham Shopwatch and Stockton Shopwatch which my radio picks up fine. Tees VTS is also very clear in my house.
