Sembcorp utilities
Scanning radio frequencies for the North East
bpoolfc95
Sembcorp utilities
Post by bpoolfc95 » 24 Jan 2012, 19:07
Hi all, ive recently just inputed sembcorps freqs into my scanner along with the fire handies. It sounds like sembcorp have gone digital as two of there freqs are sounding digital. Has anyone recently heard them and do you think you could pick them up around Sunderland. I hope they havent gone digital and it seems daft if they have. :?:
bpoolfc95
Re: Sembcorp utilities
Post by bpoolfc95 » 24 Jan 2012, 19:14
I wonder if its anything to do with the solar flare.
liamcarbin
Post by liamcarbin » 24 Jan 2012, 23:26
I've had to turn my scanner off today, too many freqs getting interference and needing to be locked out!!
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
Moonraker Skyscan Mobile Antenna
R820T Dongle ADSB Receiver
TYT-MD380
kath
Post by kath » 26 Jan 2012, 19:55
i still get them on 443.1375 here in loftus
smoggy07
Post by smoggy07 » 27 Jan 2012, 15:11
bpoolfc95 wrote:Hi all, ive recently just inputed sembcorps freqs into my scanner along with the fire handies. It sounds like sembcorp have gone digital as two of there freqs are sounding digital. Has anyone recently heard them and do you think you could pick them up around Sunderland. I hope they havent gone digital and it seems daft if they have. :?:
Sebcorp? what site? I have one of those here on teesside, they use a trunked net in the 44x area and I think they`ve got conventional pmr repeaters either onsite or up on eston nab (cant remember if it is at eston nab or onsite and cant check the wtr at the mo)
26TM234
bpoolfc95
Post by bpoolfc95 » 27 Jan 2012, 18:45
Yes the Teeside site(s). I think ive picked them up once and that was months ago. I hope im not just out of range as im not far from sunderland.
smoggy07
Post by smoggy07 » 30 Jan 2012, 12:37
bpoolfc95 wrote:Yes the Teeside site(s). I think ive picked them up once and that was months ago. I hope im not just out of range as im not far from sunderland.
WOW!!!!!! :lol:
I`m not far from them and I have problems getting them some times lolol
That said, I sometimes get a control channel for the busses from sunderland way every now and then
26TM234
bpoolfc95
Post by bpoolfc95 » 30 Jan 2012, 16:47
Smoggy, whats the freq for the buses you get. I cant input some bus freqs on my scanner as they arent cover in bands. :x
smoggy07
Post by smoggy07 » 30 Jan 2012, 18:22
bpoolfc95 wrote:Smoggy, whats the freq for the buses you get. I cant input some bus freqs on my scanner as they arent cover in bands. :x
It`s 202.462500 (if it doesnt fall in one of the scanners 'gaps')
you might hear control channel then it`ll die and the bloke will talk then the control channel will come back again (if it`s the one I`m thinking of so it maybe a single channel trunk, may not)
[EDIT]
it is a single channel trunked system
Code: Select all
Details for licence number 0067025
Start a new licence search
Licence holder details Licence holder 	Wear Buses
Contact name 	Company Secretary
Telephone 	01914205050
Email
Address 	117 Queen Street
GATESHEAD
NE8 2ST
Licence details Licence class 	Business Radio (Technically Assigned)
Frequencies and locations
Location(s)	Channel(s)
NZ 183 476 	TX: 202.4625 MHz
RX: 194.4625 MHz
Bandwidth: 12.5 kHz
Found this one aswell though close by and uses the same freq on their system
Code: Select all
Details for licence number 0045927
Licence holder details Licence holder 	Go Ahead Northern Limited
Contact name 	Mr Kevin Carr
Email 	kevin.carr@gonortheast.co.uk
GATESHEAD
NE8 2UA
NZ 271 593 	TX: 202.4625 MHz
RX: 194.4625 MHz
Bandwidth: 12.5 kHz
NZ 271 593 	TX: 202.2625 MHz
RX: 194.2625 MHz
Bandwidth: 12.5 kHz
NZ 184 474 	TX: 201.8625 MHz
RX: 193.8625 MHz
Bandwidth: 12.5 kHz
NZ 271 593 	TX: 206.1625 MHz
RX: 198.1625 MHz
Bandwidth: 12.5 kHz
NZ 271 593 	TX: 205.7125 MHz
RX: 197.7125 MHz
Bandwidth: 12.5 kHz
RX: 194.4625 MHz
Bandwidth: 12.5 kHz
RX: 194.2625 MHz
Bandwidth: 12.5 kHz
RX: 198.1625 MHz
Bandwidth: 12.5 kHz
RX: 197.7125 MHz
Bandwidth: 12.5 kHz
26TM234
bpoolfc95
Post by bpoolfc95 » 03 Feb 2012, 20:41
Hi all, ive picked sembcorp utilities up tonight quite a bit. It was about half past 6 and they were doing radio checks and i heard them talking to an ambulance. At least i know im not to far away. Im amazed at how far i am and how clear i can hear them. :D
