shopping centre security
Scanning radio frequencies for the North East
bpoolfc95
Post by bpoolfc95 » 09 Dec 2011, 13:43
Hi everyone, ive got all the freqs i know of for the bridges, Eldon square and the metro centre security but have never picked them up and ive been scanning for just under a year. Does anyone pick them up, im totally confused about how ive never picked them up. :?: If anyone can, could you list the freqs. Cheers :)
g0slq
Re: shopping centre security
Post by g0slq » 17 Dec 2011, 21:59
Where are you located? - you'll need to be lucky/going some to pick up both the Bridges AND Eldon Square unless you live on high ground near Washington or Springwell Village (my location)
G0SLQ website
Icom IC-7100 + two patchleads and a broken PL
bpoolfc95
Post by bpoolfc95 » 18 Dec 2011, 14:31
Hi there, im located in washington so am high up. The only security i pick up is the galleries. Can you tell me the freqs you have for them. Thanks alot :)
g0slq
Post by g0slq » 19 Dec 2011, 11:03
I don't listen to shop security tbh. Never tried. In fact I use my scanners so infrequently it usually means a read of the manual to remember how to work them :o
G0SLQ website
jaybranch
Post by jaybranch » 19 Dec 2011, 14:03
Hi,
Some frequencies I have are:
456.050 461.55 SHOPWATCH METRO CENTRE GATESHEAD (110.9)
456.8 462.3 HOUSE OF FRASER, GATESHEAD METRO CENTRE
459.125 MARKS & SPENCERS METRO CENTRE GATESHEAD
462.3625 NEXT FASHION STORE METRO CENT GATESHEAD
456.550 462.05 ELDON GARDEN SHOPPING CENTRE NEWCASTLE
456.675 462.175 ELDON GARDEN SHOPPING CENTRE NEWCASTLE
456.75 462.25 SHOPWATCH SECURITY ELDON GDNS NEWCASTLE
However, I have no idea if any of these are valid (i.e. still in use) as more and more people are choosing digital systems.
73 & 88
26TM1979
AOR3000A
Yupiterus (a lot!!)
VX-7R
Lowe HF 150 & 225
TS850 SAT
A longwire & GR5V
bpoolfc95
Post by bpoolfc95 » 19 Dec 2011, 15:56
Obviously the users that have gone digital, bar the emergency services, that dont use tetra but another digital system can be tracked. :?: There must be a scanner out there that can monitor digital signals, not tetra. :?:
benw18
Post by benw18 » 19 Dec 2011, 18:42
There is currently no scanner on the market to decode DMR.
TDMA/FDMA technology is fairly european based and not such a big technology in the USA- yet. If DMR takes off to the extent it has in Europe in the USA then there is a possibility that someone will develop a scanner capable of DMR decoding.
One of the selling points for TRBO and alike is the security the system offers, albeit not anywhere near Airwave (TEA2 etc), but generally speaking it is very hard to decode- unless you know certain information about the system. Unlike a conventional analogue system where you only need the frequencie(s) and CTCSS tone, a digital system would require you to know colour code, group code(s), encryption key (if used). Bearing in mind without the correct group code the radio will not unmute to incoming transmissions and there are millions of group codes to choose from!
I have no doubt there will be a scanner one day to decode DMR, but I think that is still a long way off!
g0slq
Post by g0slq » 21 Dec 2011, 22:15
I bought a BCT-15 (Uniden) over in the States a few years ago. The set has all the major frequencies pre-programmed by state , SO I scrolled to Florida, and just let it do its stuff! - ideal for travellers who don't have the facility to find the local important frequencies.
When I mentioned how all our emergency services were scrambled and Tetra etc. the Americans were horrified. A lot of spouses/partners have scanners on at home whilst their loved ones are working for the emergency services - it is their democratic right to have this information! - pity we don't have the same rights.
G0SLQ website
snapey75
Post by snapey75 » 21 Dec 2011, 23:34
Reading some of the American forums it seems DMR and NXDN is very popular over there. I think you can listen to the digital systems using a pc and DSD software with a discriminator output socket on your scanner provided they are not using encryption. The problem with digital it is so easy to encrypt, i just cant see a scanner being developed just to listen to a few systems that are not encrypted.
Most of the shopwatch and security systems will now use encryption, thats unless they want to use mixed radios such as Motorola and Hytera because their encryption is not compatable.
Neil
benw18
Post by benw18 » 22 Dec 2011, 16:02
Yes, there is some Linux based software out there which allows you to decode DMR.
Many of the original TRBO systems did not have encryption purely for the fact the firmware had not been released which included the encryption function.
Also, it's worth bearing in mind that with TRBO there are 2 types of encryption- Basic and Enhanced. Basic privacy provides 256 pre-programmed keys to choose from. Any radio which has the wrong key will hear garbled transmissions. Whereas, Enhance privacy allows the user to create their own key. Any radio with the wrong key will not even un-mute to allow the garbled transmission!
The whole argument about Tetra/Airwave being so heavily fortified is still up for debate really. I would (personally) rather it be the way it is... I can remember the old analogue days of Police comm's and the sort of information that was passed over the air. Some harmless and some not so harmless. My local force had talk-through enabled 95% of the time, thus allowing both sides of the convo to be heard rather than just the dispatcher.
I's also worth bearing in mind that even back in those days most forces were able to used basic encryption! I'm sure there are a few people on here that the remember the dispatcher asking units to "go key 1/2/3"!
troffasky
Post by troffasky » 04 Feb 2012, 16:05
440.575 seems to be Metrocentre as well.
troffasky
Post by troffasky » 04 Feb 2012, 16:40
and 440.95
woodturningbypaul
Post by woodturningbypaul » 29 Feb 2012, 17:40
hi
I have just logged on and seen this post, I work behind the Metro centre and regularly hear com’s on theses from cleaners, security and the maintenance
442.550 mhz
449.400 mhz
456.800 mhz
440.575 mhz
462.3625 mhz
456.050 mhz
459.125 mhz
What have you got for the Galleries, I have listened while sitting in the car park but been unable to find them
Paul
bpoolfc95
Post by bpoolfc95 » 02 Mar 2012, 09:15
hi woodturningbypaul, i am sure these are the but i think one or two i havent labeled as the galleries, just shopwatch but am sure they are right. 462.25000
453.02500
453.60000
456.02500
I can confirm at least two of these are the galleries. Also theres a strong digital sound, like mototrbo, but you do eventually hear talking after this. :)
handyguy2002
Post by handyguy2002 » 02 Mar 2012, 15:19
I get the galleries using 456.350
Binatone 950
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
